Starting issues
Old Sep 5, 2006 | 04:38 PM
LoveLEE143's Avatar
1983 240D, 1989 300E
Starting issues
I have a 1989 300E. I live in Atlanta and work in New York right now so I don’t drive the car during the week. In the past month when I come home on Friday and get in the car it has been very hard to start can take 5 mins. Once started when I come to a stop and just have my foot on the brake the car will die. If the car is in Neutral or Park no problem. So when I come to a stop I keep my foot on the gas and brake, or keep the car in N. When the light changes I floor it, the car will putter for 10 seconds or cut off and then it just takes off spinning the tires. It will do this until I park the car for an hour or so and it is fine the rest of the weekend. It will start on first try and drive fine. It does idle very rough now though. Could this be my fuel pump, fuel filter, fuel lines, or any other suggestions? Thanks for your help in advance.
Old Sep 8, 2006 | 06:08 AM
Falconeer's Avatar
Mercedes Benz 300E, 1991
hi,
I recently recovered from this one!
Change your fuel filter. This might also be happening due to bad injectors. Donot change them yet, try putting a couple of bottles of injector cleaner fluid in the tank and see what happens. Take the car on a long drive. If this does not make a difference, it might need new injectors.
Old Sep 9, 2006 | 04:30 AM
Hound's Avatar
1996 C36 AMG, 2013 Dodge Dart Turbo 6spd
i had a similar issue come up after having the car sitting for 2 weeks without being driven, i got some of the Lucas Injector cleaner, put in a almost full tank of gas then put that in, now it runs nicely, although it does shutter from time to time when idleing, but i think that is a different issue. Hope that helps. I got the injector cleaner from my mechanic for $5 CDN stores here sell it fro around $6 CDN. Best $5 i've spent
Old Sep 9, 2006 | 06:35 AM
KarlBenz's Avatar
Mitsubishi Outlander 2012 AWD
Do not overlook the overvoltage protection relay on these cars a very troublesome and difficult item to diagnose Located near the battery small square aluminum relay with fuse on top if more than two years old renew it
Old Sep 9, 2006 | 06:55 AM
Falconeer's Avatar
Can you post some pics of this, please?
Thank you.
Old Sep 11, 2006 | 09:36 AM
shadowgriffen's Avatar
is a German Tank
Thank you.
Follow this Link, Post #18 I show pics of where its located.
https://mbworld.org/forums/showthrea...&highlight=OVP
