Coolant indicator light
Old Oct 10, 2006 | 04:50 PM
jpganman's Avatar
Guys,
My coolant indicator light comes on and stays on - yet my coolant level is fine. I called the dealer and they sid $38.75 for the piece that connects to the reservoir, they sell them all the time as they get corroded.
Has anyone had this happen and did this piece fix the issue?
Thanks for any responses.
Old Oct 10, 2006 | 07:02 PM
ptoro01's Avatar
86 W124
try cleaning the electrical connections as they can get very corroded around water and such
Old Oct 10, 2006 | 07:24 PM
PaulX608's Avatar
2011 VW cc, 2004 ML350
The coolant level sensor is part # 124 540 02 44. You can get it for less than $20 here.
Old Oct 10, 2006 | 08:10 PM
jpganman's Avatar
Thanks for the help guys
Old Oct 12, 2006 | 03:53 PM
mhorn's Avatar
1991 300E
I had the same problem
The little clip that attaches to the coolant sensor corroded out. I bought a new coolant sensor that sits inside the tank, but couldn't find the clip part. I tried to rebuild it with some pieces I cut out of a coke can but it didn't work so I just unhooked it. What is the part number for the clip?
Old Oct 13, 2006 | 10:10 PM
jpganman's Avatar
I have a good MB shop that ended up cutting the wire and soldering in new pins. Fixed the problem.
