axels
Old Oct 23, 2006 | 07:27 PM
bjay51d's Avatar
1989300CE(sold),1996Accord,02CBR954
axels
I think I need axels.I so fu@#ing pissed the car is ringing my wallet dry. I have a 89 300 ce and know theres 2 different axels one for $150 without skid control and $400 with.Anyone have any experience with this? if so where can I get axels cheap? and is there anything that should be changed while I'm at it ?
Old Oct 23, 2006 | 07:32 PM
ptoro01's Avatar
86 W124
and why the Fu*k do you need axels?
I have a full parts car but I want to hear this story
Old Oct 23, 2006 | 08:09 PM
bjay51d's Avatar
Well I'm not 100 percent sure.But i owned a few hondas and they all made the same exact noise that my benz is making.When I make a turn and accel something on the left rear starts clicking.I'm going in to my mechanic friend tomorrow to see what the deal is for sure.I'm willing to put money on it thats its the axels.
Old Oct 23, 2006 | 08:27 PM
CDP's Avatar
CDP
W124's
check the control arm.
Old Oct 23, 2006 | 08:28 PM
ptoro01's Avatar
86 W124
I asked before I have positively never heard of an axel going bad, if you hit something then yes but your benz has a thick solid axel with 2cv boots at the end that ive never heard of being broken unless something slashed the boot open. Since the rear wheels arent associated with steering those dont flex and dont wear out. You may need a bearing but thats a whinny noise. Clickin will either be exhaust hitting the side or a rear diff. Most likely bushings in the rear suspension or it just creaks cause its prolly cold in NJ and worn out bushing make noise.
For you to need an axel, I was looking forward to hearing about how you hit an engine that fell out on the highway or something ridiculous like that
Old Oct 23, 2006 | 08:38 PM
bjay51d's Avatar
I hope youre right...Those chumpies are expensive.What exactly am I looking for in the control arms?
Old Oct 23, 2006 | 08:39 PM
ptoro01's Avatar
86 W124
gremlins
Old Oct 23, 2006 | 09:05 PM
bjay51d's Avatar
I really dont know the history on this car. I did a vehicle check on the car and it came up clean..But it was a texas car and the interior was changed to black from a newer year.The exhaust was rotted and the rear breaks was seized.There could be a chance that this car either got flooded or it was out of commission for awhile.
Old Oct 23, 2006 | 09:46 PM
YNVDIZW124's Avatar
lots of cars
Are you sure is not an emergency brake part that fell off or hitting something? Your lugs maybe too long?....Bad bearings will hummm all over the place but i don't think an axle could make a noise like that...
Old Oct 23, 2006 | 10:15 PM
ptoro01's Avatar
86 W124
sounds very much like a flood, get the whole underside checked out, suspension components and flex discs for cracking. If it was indeed a flood and you only owned it for a little while, get the tranny fluid changed along with diff fluid. Flood can damage rear diffs very quick if water leaked in. The control arms have offset bushings in them and thats how your alignment is adjusted so get all the rubber components checked out. If you spray all your control arm bushings with dw40 and the noise stops then thats where the issue is.
Get your car to the doc for a check up
Old Oct 29, 2006 | 11:29 AM
bjay51d's Avatar
Havent had chance to go to the mechanics yet.It did rain here yesturday and I noticed the noise was gone. I guess that maybe the bushings.I'm gonna spray some silicone spay on everything and see how that pans out.
Old Oct 30, 2006 | 03:57 PM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
When I first put my amg hammer wheels on the lugs were too long and broke the springs ont he parkign brake shoes. the spring was bouncing around inside the hub and making all kinds of noise not to mention a squealing on the car which would go away on and off.
Another culprit could be a wheel bearking that has gone bad, where it can make noise too.
Either way I highly doubt it is axels. I have seen my mechanic replace axels once and that was on a 40 year old car.
