Still cleaning up the engine
Old Nov 3, 2006 | 09:57 PM
NorCal124's Avatar
W124
Just a couple things I've done in my process of getting the engine a bit more spiffy. I painted the airbox cover and the exhaust manifolds. Came out ok.
Attached Thumbnails Still cleaning up the engine-image1.jpg   Still cleaning up the engine-image2.jpg   Still cleaning up the engine-image3.jpg   Still cleaning up the engine-image4.jpg
Old Nov 3, 2006 | 10:01 PM
oneill_1's Avatar
MB 300E | BMW M Coupe
Looks great!!!
-OG
Old Nov 3, 2006 | 10:08 PM
Eliot's Avatar
Range Rover Classic
Wow.. more than okay by my standard
Old Nov 3, 2006 | 10:35 PM
AMG_Fred's Avatar
Mercedes-Benz w124
well done, Now do mine.
Old Nov 4, 2006 | 01:29 AM
xudeck's Avatar
1988 300E
Whoa, that looks good. What kind of paint did you use for the Air box cover and also for the exhaust manifolds? Did you sand them down and stuff ? Could you provide a detailed instruction. I have been meaning to do it, but don't have the info on how to.
Old Nov 4, 2006 | 01:47 AM
NorCal124's Avatar
W124
For the airbox I couldn't find the right kind of gunmetal color in a high temp paint I liked. I found the right color (graphite) from a wheel paint. I took the cover and used aircraft grade paint remover and sanded it after removing the old paint. I primered it using high temp primer, painted down the graphite, and set a couple coats of clear. The key is to be patient, don't try to set down the heavy coats at once. Do light coats w/ a flash period of 10 minutes in between. For the manifolds I cleaned the area off using some engine cleaner, masked off the areas I didn't want painted and sprayed with some high temp flat black (the 1200 degreee kind). It's all about prepping what you're painting, I've messed up enough times to realize that.
Old Nov 4, 2006 | 01:51 AM
natural_person's Avatar
1992 Mercedes 400E
Very nice! Looks sharp.
Old Nov 4, 2006 | 02:01 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
Looks smexy!
Old Nov 4, 2006 | 08:43 AM
bjay51d's Avatar
1989300CE(sold),1996Accord,02CBR954
nice job indeed...This could be your side business.I can help you get your name out there.Just do my engine bay and youll have a promo car.
Old Nov 4, 2006 | 01:36 PM
CDP's Avatar
CDP
W124's
Looks good Christian!
Kind of makes me miss my 300E so I can play with my engine like that.
Old Nov 4, 2006 | 05:43 PM
NorCal124's Avatar
W124
I'm sure you can do that to your 420, just use your imagination.
Old Nov 4, 2006 | 05:45 PM
YNVDIZW124's Avatar
lots of cars
Anyone need a extra valve cover for powder coating? I have a extra oil pan too..
Old Nov 4, 2006 | 10:00 PM
Eliot's Avatar
Range Rover Classic
Its giving me ideas for my project Land Rover. The original silver paint is pealing off the engine block and I'd like to clean it up.
How did you remove the rust from the headers?
Old Nov 5, 2006 | 04:07 AM
NorCal124's Avatar
W124
I did nothing to the rust. If it bothers you try scuffing it up with some sand paper or try shooting some of that paint that turns rust into black primer (I forget what its called). If you lay enough coats of high temp paint you should be able to seal off the rust.
Old Nov 6, 2006 | 05:19 PM
myfirstbenz's Avatar
95 E320, 19 Ram 1500 Hemi, 21 GLS 580(wife)
i'll be impressed if the paint stays on the exhaust manifolds.
Old Nov 6, 2006 | 06:31 PM
mgw_300e's Avatar
Dora the Explorer
there is a paint that is specifically for exhaust parts, as opposed to just high-heat applications.
Old Nov 7, 2006 | 01:01 AM
I know, I have tried them, and never had anything stick on manifolds. I painted the manifolds on my w108, built and detailed/painted an Austin H. engine, and a XK140 engine. The Jag engine had factory porcelain on the manifolds, but even that started to chip in places after 50 years. Various types, methods, engines, and Never did it last
If it works, ie lasts 10,000mi, i'd love to know what it is.
Old Nov 7, 2006 | 01:17 AM
NorCal124's Avatar
W124
I painted the manifolds knowing it wouldn't last forever. I just had a can of duplicolor high temp ceramic paint lying around and decided to try it out. It's temporary until I have my spare manifolds ceramic coated.
Old Nov 7, 2006 | 01:00 PM
Ah yes, that makes sense. Going the JetHot (sp?) route?
Old Nov 7, 2006 | 04:00 PM
mgw_300e's Avatar
Dora the Explorer
how much does that cost?
Old Nov 7, 2006 | 05:24 PM
NorCal124's Avatar
W124
about $240
Old Nov 7, 2006 | 05:29 PM
mgw_300e's Avatar
Dora the Explorer
about $240
are you doing just the manifolds, or the downpipe as well?
Old Nov 7, 2006 | 05:39 PM
NorCal124's Avatar
W124
Probably just the manifolds
