Euro Headlight Connector Melted! Pic
So my passenger side headlight is having issues. The 3-pin connector that connects to the main headlight bulb has melted so badly that it caused one of the wires to come unseated. It's beyond repair.
They are TYC Euro headlights (obviously not as high-end as the Bosch or Hellas), and they came with H4 bulbs. The driver's side is completely fine. No sign of melting at all.
So my questions are:
1) Why do you think this happened?
2) Where can I buy a replacement for this female 3-pin connector?
Here's what I'm talking about:
![](http://i66.photobucket.com/albums/h255/peteraeschliman/DSC00761_resize.jpg)
is a German Tank
Good luck finding that socket, try ebay for used/cracked single euro light casings, its as close to getting the socket as you'll get...or you can try the original seller.
either way, good luck
![Sadwavey](https://mbworld.org/forums/images/smilies/sadwavey.gif)
yeah, thanks. This is definitely the downside of using aftermarket stuff- finding parts can be tough.
I bought these headlights from Katmac.com, which I know lots of members have also done. The same guy sells lots of Euros on ebay. I've had them for 2 years, and the drivers' side is completely fine. I used the H4 bulbs that came with the kit and was assured that they were correct. I haven't changed the bulbs since I bought them... I'm not sure what the wattage is since the katmac site doesn't list it.
I emailed the guy last night to see where I can buy a new connector, and I also asked him why this would happen. Obviously just replacing the old connector won't fix the root cause.
Can anybody please recommend bulbs to me that would be sure to work properly?? My lights are plenty bright as-is, so I just want a recommendation on something safe! I know lots of you guys have euros, so please advise!
is a German Tank
well I have the alternatives to euros, but I'm pretty sure that your Volt + Watt combination should be similar to mine:
12v 55 watt.
and that sounds like a safe bet to me.
12v 55 watt.
Poor quality plastic connector. If you do find a store, ask if they have the 'ceramic' type, will not melt in any way. Even the originals will come to a point of melting after very long years of use.
Stock H4 bulb-60/55 watts
Interesting. Thanks guys. But it just seems to me that this shouldn't happen if everything is set up right. Maybe I could just use ceramic connectors and forget about it. It just makes me nervous that something else isn't right.
I'm guessing that this connector, or one very similar to it, is readily available. I say this because lightbulbs are fairly standard. So I would assume that the connectors are as well.
What lightbulb models do the rest of you guys use in your euros?
If you really want some peace of mind, replace both connectors with ceramic then have built-in wiring replaced, including the fog lamps, with thicker and branded automotive wires.
Stock oem H4 bulbs are the 55/60 watts specs. Choices are Bosch, Hella, Philips, Narva. Most of them have different models to suit your driving preference.
is a German Tank
Love em
![Euro Headlight Connector Melted! Pic-benzeyes.jpg](https://mbworld.org/forums/attachments/e-class-w124/91538d1468963778t-euro-headlight-connector-melted-pic-benzeyes.jpg)
1 Post
2000 C230K and 2002 ML320
It looks like too high wattage in your bulb... I recommend the Sylvania Xtravisions... they are the same as european SilverStars... the US SilverStars have a blue coating on them that reduce useable light in rain... they look good on dry roads, but suck in the rain.
is a German Tank
I have H1s.
No, he means that the blue coating tints the light blue. Blue light is not safe for intense driving conditions because your eyes can not focus on blue light, thus the use/need for yellow fogs for bad weather.
1 Post
Yep... I am in Portland... I just adjusted my headlights properly and I can see better now... I thought these DOT lights sucked worse than my 93 Civic's... but actually once aimed correctly, they are 10x better than those.
Alright, I found a cheapo replacement plug after a bit of searching:
http://sports-imports.stores.yahoo.net/buhlipl90.html
I also found these even cheaper cheapos on ebay:
http://cgi.ebay.com/ebaymotors/H4-90...ayphotohosting
I think I'm gonna go the ebay route. It's so retarded that I'm paying twice the purchase price on shipping!
1 Post
08 Lexus GS350 AWD. 08 Lexus RX350 AWD - wife's. 94 MBZ E320 - still have it.
I think loose female connector would cause overheating also. I've been using 110/130 watts PIAA bulbs for the last 7 years and never had any issues with overheating.
Mercedes-Benz w124
high wattage bulbs will cause the thing to melt. just buy a new harness, they are cheap. I bought the cheap ones on ebay and look very similar to the tyc ones already. and I just got some bad luck, I was trying to adjust the beam pattern, and only the height adjustment works on my passenger side. Moving the other headlight knob apparently does nothing, is there a way to do it manually?
Range Rover Classic
I bought them from Ebennz who used to post here. He has a Euro Lighting Import shop. The ceramics are 14 USD or something of the sort. Just clip the standard wires and feed them into the hella socket.
Yeah, the ones I bought on ebay just arrived today. So I'll be soldering them in tomorrow. I bought new light bulbs, but I may not install them... cuz the plugs I bought claim to be super heat resistant and are apparently made for overwattage bulbs. We'll see.
