Need 400E or E420 for engine swap...
I look forward to documenting every step with pics, write-up, etc. but any info you guys might have out there would a tremendous help, links to other sites or technical data, etc. Thanks again for the help in locating one.
As for the firewall I saw that on the website you are referring to, and while no custom job is easy, the challenge of the job is half the fun. This summer I helped my neighbor drop a Corvette/Impala engine into his 88 4 door Jeep Cherokee, we did a manual swap a few months before. I learned that the engine going in part is really the easy part, using the new space contraints to make all the accesories work is the challenging part, however with the donor car there in front of me, cd's with tech data, I don't expect it to be overwhelming - challenging, yes but not impossible.
This link just kind of shows you his progress... It isn't very technical. But he would be a good guy to ask! It's been a year in the working for him, but he's only a few weeks away from turning the key...
http://www.benzworld.org/forums/w124...-v8-400ce.html
I e-mailed you abt 5hrs ago...did you get that?
"We were taking some measurements today, from a 400e vs 300ce. Trans tunnel is the same width, firewall is the same. The engine bay is the same dimensions firewall to radiator support."
When you remarked the firewall & trans tunnels were not the same and would need modification did you mean from a 300TE or are you just implying you think there will be modifications but don't really know for sure?
I wouldnt mind a 420ce
