Oil light question
unplug the level sensor from the oil sump, clean with contact cleaner really well, spray both sides, the plug and the sensor, let dry...inspect plug end for damage (i.e. cracked plastic end, frayed/broken wires, loose fitting connectors, ect). if this solves it, great, if not, suspect the internal sending unit.. the gasket would be changed also (duh) and the job is no biggie, when you have drained the sump during oil change..just remove & replace...
if you have a 94+, it might be early warning of the dreaded wire harness issue.
in other applications, I have seen a 'level' light also indicate LOW pressure ( sort of like the fuel gauge & reserve light,) but if that works in this case, then there is a tie-in to the pressure sender, which is near the filter housing..
the sensor might only be dirty, operates similar to low fuel sensor, open contact= light on, closed= off
use a multi meter to check the contacts on the sensor, and the harness for short/open in wires.....
