Oil Consumption
best regards.
head gasket, timing chain cover, rear main seal.
My car eats up oil as well, but mine does leak.
. I am replacing the head gaskets. If you see and oil build up near the headers/exhaust manifold or smell oil burning after you have driven for a while, it usually means you have a small leak somewhere that is dripping onto the exhaust. This is not really a big deal, just get it fixed pretty soon.My car had a 115,000 miles on it when I sold it and used no oil. The valve seals get hard with age and allow oil to pass through with the fuel and it just goes out the exhaust. The CAT will burn up the oil and you won't see it behind the car unless it has a severe problem like the rings are bad.
Good Luck
Take Care
