No spring pads
Old Mar 6, 2007 | 11:19 AM
mouramen's Avatar
1985 W124 200D
No spring pads
Hi guys,
If i remove my front spring pads (3 dents) and roll without them, how much of a drop will i gain?
Any inconvenient in driving with no pads?
Old Mar 6, 2007 | 11:33 AM
Legoinsaniac's Avatar
1992 400E
The pads you currently have are 18mm thick. 2-bump pads are 12mm, and 1-bump are 8mm. If you completely remove them, you'll get a drop a little greater than 18mm. If you completely remove the pads, you may experience increased noise due to metal on metal contact, and possible rust formation if the spring rubs away the undercoating on the perch. Maybe just switch to the smallest pads? You could even cut those in half if you wanted. That'd probably be better than running w/o them. You'd still get a drop of >10mm
Old Mar 6, 2007 | 10:22 PM
ZedStyle's Avatar
Youngtimer
send a pm to Federic0W124, he has been running without pads for a very long time, he would be able to give you the best response
Old Mar 12, 2007 | 06:37 PM
Federic0W124's Avatar
1992 400E
no spring pads= no biggie.
my car had one bump pads all the way round when I got it. So when I did the spring install I didn't bother putting them back.
my exhaust is so loud I wouldnt hear **** anyways.
so yeah...no ill effects here.
Old Mar 15, 2007 | 04:50 AM
ronald7410's Avatar
1992 300CE
PMED^^^
