W124 Gasoline - Will Not Start
Old Mar 14, 2007 | 03:28 AM
Starship's Avatar
W124 300E
After sitting for 10 days she just wont start - turns over well but will not fire -have fuel and spark up but doesn't even look like starting - got a couple mini back-fires is all - HELP!!!!!
Old Mar 14, 2007 | 04:12 AM
tokleman yanass's Avatar
'86 300e
what was it running like before the 10 day rest?
Old Mar 14, 2007 | 11:25 AM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
Did a wallaby chew through your wiring? Seriously, look for something like that.
Old Mar 14, 2007 | 03:36 PM
Starship's Avatar
W124 300E
Just Fine
Old Mar 14, 2007 | 05:44 PM
'86 300e
hmmm...yeah, maybe not a wallaby, but a rat or something. Something has to have changed, I regularly leave my car sitting up to 6 weeks when I go overseas and it always fires up first bang, well not quite but only needs enough cranking to get some fuel pressure. How do you know its getting fuel?
My understanding (rudimentary) of the fuel pumps is that its set up to pump only when the engine is turning over unlike electronic injector systems where common rail pressure is pumped up when the key is turned on. The next thing is the cold start injector but there's no reason why it wouldn't work apart from the proverbial rat chewing through the wires...
Old Mar 14, 2007 | 11:04 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Check the fusing for the OVP relay which is located behind the battery.
Your symptoms are typical of a blown fuse.
Old Mar 16, 2007 | 06:54 PM
Starship's Avatar
W124 300E
Injector Cleaner Problem
My MBZ Techo reckons this is a result of me adding injector cleaner to the fuel tank and only travelling a very short distance (70kms), before letting it sit while away on vacation. Seems dislodged glunk is probable causing the fuel pump piston to stick. Is now starting intermittantly and he recommended I use up the existing fuel (and injector cleaner), asap and refill with fresh fuel to finally overcome the issue.
On the other hand the cleaner has really cleaned up the injectors and got rid of the slight lag an starting.
Old Mar 17, 2007 | 07:59 AM
RBYCC's Avatar
Best to use Chevron Techron on a regular basis, say every 3000 miles as MB dealers in the USA recommend it. It will keep your fuel system clean.
Glad it started for you
Old Mar 17, 2007 | 01:49 PM
Lorinser880's Avatar
'87 260E
Check OVP fuse. If that's ok, switch key to on position then try to listen to the fuel pump at the right side of the rear seat. Or you can remove the fuel pump relay behind the battery and short terminal 87 & 15 with a small jumper wire then start, if it does your relay is kaput. Good luck.
Old Mar 17, 2007 | 09:10 PM
Starship's Avatar
W124 300E
Pump fine and starting improving - Iam confident it was the injector cleaner gumming up the pump piston.
