Mystery Door Connector
It will have power on one side at all times as the circuit is broken by the door switch via the earth lead.
What voltage do you see when it's pulsing and do you see a voltage across the the wires or are you measuring from each wire to earth?
USA wiring diagrams designate these as "E17/" and they are connected to the interior lights that operate when the door is open.
Is one of the wires red, and is this where you read 12 volts to earth?
Most manufacturers make wiring harnesses for all possible options, so you may find connectors that aren't being used.
