tranny cooler lines/ fuel pump
Old Mar 18, 2007 | 01:58 PM
jpganman's Avatar
My tech is telling me i need to replace the tranny cooler lines, anyone done that yet?
He also says my fuel pump is leaking but i check the reservoir regularly and see no signs of a reduction in fluid, shouldn't i begin to hear the weening of the pump if the fluid gets low?
thanks for any input
Old Mar 19, 2007 | 11:00 AM
overboostTSI's Avatar
90 300e and B5 S4
It is common for the transmission lines to start leaking on higher mileage w124s'. The job itself is not that difficult you will just loose a little trans fluid when you disconnect the old lines.
