E420 compression ratio, forged internals?
Old Apr 4, 2007 | 01:40 PM
mnmike's Avatar
Ive been doing a lot of reading on both the S class and more recently the W124 E class models with the V8's. It seems the motors can last forever (though the wiring harnesses sometimes fall apart).
Anyway, does anyone know what the compression ratio of the W124 400e and E420 are (I know at some point it was slightly changed too).
Secondly, is the crankshaft, rods or pistons forged?
Old Apr 4, 2007 | 01:58 PM
steve211's Avatar
'01 C240, ‘98 S320, '97 740IL, ‘06 X5, '87 GTI
From what I remember reading in the Bentley published "W124 E-class owners bible", it went from 10:1 to 11:1 in 1993 when they increased displacement to 4.2L, while HP went from 268-275. The designation to 420 did not change until 1994 when the "E was moved to the front of the name.
Steve
Columbia, SC
Old Apr 4, 2007 | 02:06 PM
CDP's Avatar
CDP
W124's
Steve is correct.
The compression was 11.0:1
275HP @ 5750RPM
295TQ @ 3900RPM
Old Apr 4, 2007 | 03:14 PM
mnmike's Avatar
thanks guys, you wouldn't happen to know if it has a forged crankshaft, rods or pistons?
I take it by the relatively high c/r that people don't supercharge or turbo these motors very often..
Old Apr 4, 2007 | 06:31 PM
myfirstbenz's Avatar
95 E320, 19 Ram 1500 Hemi, 21 GLS 580(wife)
I know that some mods can be done to the intake manifold that drastically improve power, and allow you to run 87 octane... i'll try to find the post later.
Old Apr 4, 2007 | 08:17 PM
Eliot's Avatar
Range Rover Classic
They'd make for a great turbo/supercharger project except there isn't any room in the engine bay. You can always toy with the compression ratio.
Sauber ran a twin turbo M119 at Le Mans.
Old Apr 4, 2007 | 09:41 PM
CDP's Avatar
CDP
W124's
Or... You can run a rear turbo set up.
Old Apr 4, 2007 | 10:51 PM
Federic0W124's Avatar
1992 400E
LOL i bought that **** for my Z28.
I never did install it though...
Old Apr 4, 2007 | 11:09 PM
Don M's Avatar
The rods are forged. The pistons are cast, but iron coated on the running surfaces. The block is parent bore and uses no iron liners.
The crank is probably cast, but induction hardened. I am tearing a M119 apart in the coming months and will tell you what I find.
Old Apr 5, 2007 | 12:03 AM
Fantastic Stable you have there Don
Old Apr 5, 2007 | 10:37 AM
mnmike's Avatar
I thought M119 was the engine code for the 6?
Old Apr 5, 2007 | 11:35 AM
CDP's Avatar
CDP
W124's
Nope.
Old Apr 5, 2007 | 01:23 PM
M103 for 12 valve, m104 for 24 valve
Old Apr 17, 2007 | 03:04 PM
bicylindrico's Avatar
I know of the m119 engine having a forged steel crankshaft.
Old Apr 18, 2007 | 04:04 PM
Ben92's Avatar
There is plenty of room underneath for remote mounted turbos. But there would have to be careful planning to choose proper components and charge cooling.
How about a pair of GT3071's each with their own A:W intercooler and meth injection? With proper fueling, should be good for 600rwhp with quick spool and a flat torque curve.
