Driver's side window "dropped" into the door
Old 04-06-2007, 05:54 PM
MBFANMAN's Avatar
Has anyone had this happen? Any idea what's broken and how to fix this?
Old 04-06-2007, 06:04 PM
CDP
CDP's Avatar
W124's
Problem: Window Regulator has failed or somehow managed to come off track.
Solve: Replace window regulator or fix the window itself.
Old 04-06-2007, 06:53 PM
myfirstbenz's Avatar
89 300TE, and 68 280sel
odds are that the clip that holds the window in the track came off, it is most likely in the door still, so just pull off the door panel and take a look. Look up how to do this before you get started so as not to damage anything. If regulators fail, they stop working, they don't do this, it is most likely something simple. Fear not.
Old 04-06-2007, 07:55 PM
MBFANMAN's Avatar
Thanks for the helps guys. Anyone know where I can get a "manual" for for taking apart the door panel? (ie: A Chilton or Haynes manual?)
Old 04-06-2007, 09:14 PM
i'll do a write up tomorrow, or i'll find my MB CD's and post a pdf. Time for beer and pizza right now.
Old 04-06-2007, 10:24 PM
GOODENUF's Avatar
07 SL55, 1954 Corvette, 09 E350
I had a 2001 E320 that had both rear window regulators fail. One was under warranty the other cost a few hundred dollars to remove and replace. Hopefully all you need is a clip or something. Good Luck.
Old 04-06-2007, 11:31 PM
MBFANMAN's Avatar
myfirstbenz - Thanks for your help
Old 04-07-2007, 12:09 AM
JennzBenz's Avatar
300 E
awe the same thing happened to my passanger side back window... its still down as we speak cause the insurance guy said not to fix it myself cause then i might not get the money back from it.it stopped working right after that ****er hit me.... it goes down fine just cant get it up.. it stops as if it is closed when its like 3 inches down.. not cool.. cause everyday i have to manually clean her.. i cant just quickly go into the car wash.. its brutal.
im glad to hear im not the only one.
Old 04-08-2007, 11:53 AM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold)
DIY Article
This doesn't look like fun. I tried to do this but everything I touched broke off, so good luck.
http://www.mercedesshop.com/Wikka/W124DoorPanel
Old 04-08-2007, 01:00 PM
Ah good, that's pretty much how to do it.
Old 04-08-2007, 03:06 PM
Bigpete123's Avatar
1990 300ce
it's not very hard at all. Don't be intimidated by it.
Old 04-08-2007, 10:20 PM
Nassio's Avatar
91 300CE
Hi, The window is held on the track by a silicone adhesive.
It probably dried out...
Quick Reply: Driver's side window "dropped" into the door
