HELP! How to plug spark plug wires back on!?
is a German Tank
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
GUYS WTFFFFFFFFFFFFFFFF!
so yesterday I decided to do a little "minor" tune-up to my baby. I bought a new Air filter, gave it an oil change and threw in some sea-foam, plus some new sparkies.
Well, I went ahead and removed the dist cap, along with carefully "popping" out the plugs funnels.
Well wouldn't you know, the sonofab!tch wire wouldnt snap back onto the spark plug! I tried everything in the motherEFFIN book to plug the wire back onto the spark plug to no avail!
Well after about an hour and a half of painstakingly trying to hercules the wire back on the spark plug I went ahead and used some DEMI GODLIKE FORCE which of course ended up BRAKING the connector base!
so now I have this wire with this retarded funnel end with no BASE on which to hold for leverage!
WTF did I do wrong?????!?!?!?!?!??!??!?!
I now obviously have to buy new wires, might-as-well by the whole distribution pack.
any advice before I HERCULES my way through the new set???
I'm SO f%($ing ANGRY!
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
is a German Tank
LOL
I basically tried to "plug" the wire back onto the spark plug like any other person would, but mine wouldnt "snap" back in so I basically broke it.
Have a look at your spark plug wires, they connect to the sparkplug via a "funnel", well that funnel has a plastic base (it's red, if you take off or roll down the rubber boot)
that is what I broke.
I dont have pix right now as I'm at work...sux.
Be sure the "caps" aren't on your new plugs. There is a threaded stud at the end of the plug that may have a rounded metal end that threads on to the stud. The M104 used the rounded end and the M103 used the threaded end. This may be your problem.
1 Post
93 300SE Rauch "Smoke"
Is it possible that you had the wire on ? Then forced them and they broke? When I did mine on Bigblue they came off hard but just slipped back on so easy I fig they could not be on! BUT THEY WERE!!
Smokie
Smokie
is a German Tank
thanks for the replies guys.
Well it turned out that the Super coppers had this little rubber boot attached to the plug itself, when I pulled the wire out the little rubber boot was stuck inside the funnel, making an obvious obstruction without me noticing....!
had to spend 102.00 for a new set of wires from autozone....hey at least they are BOSCH!
sux...
sux...
