Emergency Problem! Please Help!
Old Oct 4, 2002 | 07:27 PM
chupper's Avatar
89 300E
This just started today. I had my car parked (its windy today, don't know whether that has anything to do with it) for about 2 hours. I got back in and as I take off from an intersection I hear this ticking noise coming from the left side. Inside it sounds like I have a flat tire, outside it sounds like a snapping or ticking noise. It seems to fade off when I reach 50mph. I tried to recreate it. It comes best when I make right turns from a stop !?! and when the weight is being thrown to the left of the car.
I don't know if this is serious or what! I checked the wheel basically and found no sticks or anything in or around the wheel. Everything seems fine. When the car is motionless and I push down on it, it doesn't make the noise. Only when I am in motion and the wheel seems to turn. Any suggestions, is this serious?
Thanks!
Old Oct 5, 2002 | 01:13 PM
ebennz's Avatar
fuses?
check ALL your fuses.
are all of your gauges working?
this happened to me when i lost my tach, and my gauges on the left side of the instrument panel.
peter
Old Oct 5, 2002 | 01:44 PM
chupper's Avatar
Well, all fuses are OK. All guages are OK. I'm guessing it has to do more with the wheel, but I'm not sure. This was weird, because if it is something mechanical, it started immediately. There was nothing leading up to it...
Old Oct 8, 2002 | 11:20 PM
chupper's Avatar
It was the axle. The axle is bad. Thats $700 at least! Oh, boy....
thanks for trying to help
Old Oct 10, 2002 | 09:17 PM
V12BIGBODY's Avatar
03 S 500--94 BMW 325i--01 GSXR 1000
Why the axle?? You have independent rear suspention! What is wrong with it?? Are you sure it's not just the bearing?? If it is the axle just go to a junk yard and buy a used one. I needed one and I went that route it cost me $200 i've had it now for 3 yrs with no problems.
Old Oct 10, 2002 | 11:00 PM
chupper's Avatar
Well, thats what the mechanic said, but so many people are saying its just the bearing, check this out...
http://www.benzworld.org/forums/mess...1&id=11&view=t
