Climate Control Troubleshooting 1994 W124
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Hi,
When I turned on the A/C the other day all I got was hot air. A couple of weeks earlier when I tried it for the first time this spring, it seemed to be working. Now the compressor isn't engaging. I'm going to do some trouble shooting. Does anyone have:
-a (digital file) wiring diagram for the 1994 W124 climate control
- the location of the N6 relay
- most probable causes
- any suggestions on where to start the process?
Your help is appreciated.
Regards,
James
Regards,
James
Range Rover Classic
Any fault could put it in failsafe mode... which is full on defrost. Its worth checking the vacuum pods.
Hi,
Regards,
James
Regards,
James
James,
I checked when I got home....I've got on original Mercedes-Benz Electrical Troubleshooting Manual (USA) for the W124, but it only covers Model Years 1986-1992. Sorry....
Chappy,
Thanks for checking. Hopefully with the Bible and by doing some fault code checking and circuit checking I can identify if it's an electrical problem or a mechanical issue.
James
James
Here are w124 wiring diagrams.
http://mercedes.vanpeters.com/124wiring.pdf
and climate control testing
http://mercedes.vanpeters.com/climatecontroltesting.pdf
My car is a 1994 E320 with the 16 pin diagnostic block, so I'm not sure if the wiring diagrams and test procedure strictly apply, however I will look to see if I can use them.
Thanks again.
James
Regards,
James
James, your welcome. I also have a '94 E320. It will work, I've check for codes in the climate control system in the past just for the fun of it. Here's some more info from http://www.alldatadiy.com. It is a great site for learning how the car works. Between Alldata, the E-Class Owner's Bible and the Factory CD's you should have all the info you need, they all complement each other. I think all three resources are a must have. Alldata is also cheap, it is $24.95 for the first car for the first year. Renewals and additional cars are only $14.95 per year. I have alldata subscriptions for all my cars.
Anyway below is some info from alldata.
Testing with the impulse counter should be carried out for rapid fault diagnosis. The impulse counter output shows only existing faults, since the ACC system does not have memory capabilities. If one or more faults are indicated, repair as necessary and repeat the test. Be sure that fuse #7 is good, the battery voltage is between 11-14 volts and the temperature selector wheel is set to 22°C.
Connect the impulse counter to the on-board diagnostic connector.
Black lead of the impulse counter to socket 1
Yellow lead of the impulse counter to socket 7
Red lead of the impulse counter to battery positive terminal.
Turn the ignition to the "ON" position.
The LED "U Batt" will be illuminated. If the LED "U BATT" does not illuminate, check for voltage between socket 1 of the on-board diagnostic connector and the positive terminal of the battery. If the voltage is not between 11-14 volts, check for an open circuit or loose ground connection.
Test for voltage between socket 7 and socket 1 of the diagnostic connector. The voltage should be 6 - 12 volts.
Depress the start button for 2 - 4 seconds.
Fault codes will be indicated by the number in the impulse counter display window. Take note of the impulse display number.
Faults are displayed in ascending order.
The number 1 indicates that no faults are stored in memory.
During the impulse readout, The LED indicator in the fresh air/recirculation switch will blink.
Repeat step 3 until all faults are indicated. After all fault codes have been displayed, pushing the start button again for 2 - 4 seconds will repeat the fault code readout sequence
IMPULSE (FAULT) DISPLAY RESULTS
Refer to the IMPULSE DISPLAY RESULTS, then proceed to DIAGNOSTIC CHARTS for specific diagnosis.
Repair the indicated faults. Be sure to turn the ignition switch to the "OFF" position before disconnecting connectors or components unless otherwise directed by testing procedures.
![](http://mercedes.vanpeters.com/acccodes.gif)
Thanks Kestas. I guess I'm hoping it's an electrical fault, and I could eliminate that before taking it to the shop, but you are right, the pressure check is basic. I'll have to look into getting a PG or take it to the garage after doing a bit more checking.
Regards,
James
Regards,
James
![](http://cobbbuzz.com/benz/acchargetest.gif)
Let me know if you need help finding the inspection window on the drier.
-Ken
Thanks for the help! I'm not sure where the window is.
Regards,
James
James, the window is in the yellow circle in the attached picture. It's the drivers side between the headlight and ABS pump.
Ken
Ken
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
The ACC units were pretty dependable by the mid 90's and rarely fail. I am not saying it never happens and you don't have a strange fault with your car, but at least confirm there is adequate freon pressure to turn on the compressor clutch. Maybe I missed something.
Thanks everyone for your help. All the information was helpful. I did check the AC fault codes (after building a code tester) and everything was OK. I took the car to an independent local MB specialist who checked the system pressure and found the refrigerant charge low. It's been evacuated and recharged (with dye added). So far it's working OK and I haven't seen any obvious leaks. Thanks again everyone. It's great to have such a wealth of freely offered information out there!
James
James
