1990 300TE electrical gremlins
Then, the exterior lamp failure indicator came on, only when the brake pedal was applied. In doing some basic diags, I re-seated all the brake bulbs, and I noticed that the rear wiper would work. I then noticed that when I tested with the lift gate open, all the previous failures (with the exception of the wiper in the full on position) would work. I suspect that I've got a short in the wiring harness, but would appreciate any and all suggestions to confirm. Thanks. Chris
Good luck
Yes, I've taken off the rear panel. There are no obvious cuts or nicks on any of the wires. Also, there is no evidence of moisture in any of the areas. Tracing each circuit, as you suggest, is the next step. I suspect one of the wires has word hardened by the hinge point, and is making intermittent contact, which might explain why most of the circuits function near normal when the tail gate is in the full open position. Thanks.
