How do I lower a 1995 E320 Wagon?
I am thinking about a 16" factory-style 8 hole wheel (ASA from Tire rack- any good?), and they recommend a 205/55-16. If I drop the car 1" - 1 1/2" should I go to a shorter tire? What about a 17"? what sizes would you run?
I like the looks of the car in this picture, this is the color of our car.
Thanks in advance
Jeff
If you can defeat the rear load-level then you should be able to do alot.
there are a few suspension experts here that will chime in soon.
My wagon is/was lowered by my old time mechanic using SACHS sport shocks (MB OEM sportline supossedly) and what he said were sport springs from an MB coupe, but my car is significantly lower and I'm happy as hell!
as far as the rear is concerned, I have zero complaints as I'm pretty much always loaded with a bunch of stuff (baby stroller etc...etc..) so it sits a tad low
Best of luck!
Here's some info I've been digesting....
http://www.w124performance.com/docs/...suspension.txt
I don't know what the self-leveling shocks entail, but I would think you could do like shadowgriffen and just replace them with regular shocks, no?
Is the issue that nobody sells lowering kits specifically designed for the wagon? I'm sure the weight in the front of the car is simply dependent on the engine you have, but the rear might be a tad heavier than the sedans. So I'd look into the weight difference between the 95 e320 sedan and the 95 320 wagon. If it isn't significant, you will probably get away with just buying a kit for the e320 sedan.
I'm talking a little out of my ***, but that's what I would do if I were you. Also consider a camber kit. I lowered my coupe on H&R's and had to buy a camber kit recently to correct the rear (burned through a set of tires very quickly). good luck
you are definitely on to something, again lol
I'd suggest converting the Wagon to Sportline spec or at least the Struts and Coil Springs. It will provide a lower firmer ride using factory parts.
Eliot, When you say "I'd suggest converting the Wagon to Sportline spec or at least the Struts and Coil Springs. It will provide a lower firmer ride using factory parts."
That sounds great. Where to I get the parts and how mush are they? Is there an expert to call that will know the part numbers?
Thanks for all the responses!
-Jeff
[Credit to DaveM - the following is lifted from his website]
300TE Sportline Wagon (124.x90/x92 - Euro)
Front Sportline Springs
124-321-27-04 ($NA)
124-321-28-04 ($NA)
124-321-29-04 ($82)
124-321-30-04 ($82)
(higher number is stiffer, for heavier car)
Front Sportline struts
124-320-35-30 Front Strut ($214)
129-323-03-44 Shaft buffer ($13)
Front AMG strut
HWA-124-320-03-30 ($521 EUR)
Rear Sportline Springs, with SLS (self leveling rear)
124-324-23-04 (light) - ($75)
124-324-28-04 (heavy) - ($83)
Rear Sportline hydro-shock
124-320-38-13 w/SLS ($365 EUR) - (now 124-320-23-13 ?)
Rear AMG hydro-shock
HWA-124-320-07-13 (No longer available?)
AMG wagon complete suspension package,
part number: B6-6-02-0009 (No longer available?)
part number: B6-6-02-0005 ($2275 EUR) - With SLS - ($4640 US)
Spring pads / shims
201-321-09-44 - Front, 1-point (8mm)
201-321-10-44 - Front, 2-point (13mm)
201-321-11-44 - Front, 3-point (18mm)
201-321-12-44 - Front, 4-point (23mm)
201-325-09-44 - Rear, 1-point (8mm)
201-325-10-44 - Rear, 2-point (13mm)
201-325-11-44 - Rear, 3-point (18mm)
[Credit to DaveM - the above was lifted from his website]
It appears there isn't a Sportline spec swaybar (torsion bar) for the Estate. I'd suggest ordering from buymbparts.com. No one has a better price and Rusty can order anything and everything.
If you wanted to compromise you might consider the Sportline Coil Springs and a set of Bilstiens all around.
Have you made any decisions on your suspension setup? My idea with the wagon is to have the suspension setup similar to my coupe with the OE Sportline parts. Any trouble sourcing the parts?
About the wagon sway bars, the wagon Sportline kits do indeed have different bars... the front is the "limo" bar (-77-65) and the rear is the standard 16.5mm Sportline bar (-19-65). I didn't put sway bar info into that text file, only springs & dampers. The sway bar specs & part numbers are listed here:
http://www.w124performance.com/images/W124_sway_bars/
Because this is exactly what I am in the middle of, I'll chime in with what I have discovered myself on my 94 E320 Wagon.
As applied to the rear, as it seems this thread has gone, you can install the sportline wagon springs with the #1 pads and get about 3/4 to 1" of drop in the rear, this is with the "heavier" springs. There are two types of springs for the sportline rear with SLS so I am assuming that with the "lighter" ones (please refer to parts posted above by eliot) you may net a fraction more(?). The suspension works fine with stock hydros and from what I can see in flexing the suspension nothing is binding to where the Sportline hydros are required for the set up.
The SLS system, with the spring set up aforementioned, you have enough adjustment to get the SLS to the neutral position, but barely - at least on my wagon. This is important otherwise the SLS sytem will want to keep pushing your suspension up, straining your system unecessariliy until it fails prematurely.
I'll take some pics and height measurements when I get the car back from the paint shop for lower clad matching
Edit: Everything was bought through rusty and all sportline parts ordered were stocked in the USA, not GmbH. Except for my front sportline struts but it seems that I may have ordered the wrong ones...
First thing - the car looks good, but it has too many imperfections. the fit and finish does not look so fit anymore.
If you compare that car to mine (mine is older) it doesnt hold a candle to my wagons superior fit!
second thing - that grill, that bumper and the wheels
sorry but I WILL judge this book by it's cover!
The SLS on the s500,6.9 do not use coil springs at all,,,the S500 can be lowered with software the 6.9 with a big brain...the wagon is no harder than a standard w124, the all wheel drive w124 wagon is another story...I am not real good at writing instructions but i have lowered a few w124 wagons with very happy drivers still crusing around....
