Help! Emergency problem
Old Oct 8, 2002 | 06:15 PM
vertskier1's Avatar
2005 E500 4MATIC
The rear right window gets stuck about 2 inches from being completely closed. how can i fix this?
Old Oct 8, 2002 | 11:04 PM
chupper's Avatar
if you continue pushing the up button, does it making a loud ticking noise? 124's are know for regulators that go bad. The regulator helps power and enable the window to go up and down properly. You may need to replace it, either at your mechanic or dealer. When I got it replaced a few years ago on my drivers side window, it was like $90 for the parts. Good luck!
Old Oct 29, 2002 | 07:05 PM
DougandhisC280's Avatar
2008 SLK-280
I'm not kidding....take off the door panel and beat the motor with a hammer. (if it's not making some kind of other noise.)
Old Oct 29, 2002 | 11:41 PM
2008 SLK-280
Just to clear things up.....If it is making a ticking sound it is usually a regulator. (As many others have said) Many times the motor will corrode inside and need to be replaced. A quick fix though is to hit it with a hammer while trying to roll down the window. (2 person job) This will loosen up the corrosion and let the motor turn again.
