Trouble starting 300(C)E
Old Oct 11, 2002 | 09:52 AM
spinnell71's Avatar
300 CE
Angry Trouble starting 300(C)E
It takes multiple attempts to start the engine in the morning. When the engine does start the rpm's go up and the engine idles very rough then dies suddenly. If I pump the gas pedal I can usually keep the rpm's high enough so that the engine doesn't die. Once idleing, the car rides very smooth.
I have tried all different grades of gas as well as valve cleaners which have not helped.
Any suggestions??
Old Oct 11, 2002 | 12:12 PM
Jackd's Avatar
260E , 1989 (for now)
Possible causes:
*Bad fuel accumulator
*clogged fuel filter.
*defective fuel distributor
*Bad plugs/distributor cap/rotor/plug wires
*Defective Cold start valve
*Vacuum leak
and others.
JackD
Old Oct 11, 2002 | 07:25 PM
spinnell71's Avatar
300 CE
Where should I start??
Old Oct 11, 2002 | 07:35 PM
Jackd's Avatar
I'd start with items that have not been looked at for the longest time.
As the problem you are describing can have many causes. It is, at the same time, very likely or very unlikely that your first attempt will be the once resolving the issue.
I would have a good diagnostic done first by an experienced Mercedes shop. If the car did not have a good tune-up in the last 25,000mi.or so, this would be a good start.
jackD
Old Oct 14, 2002 | 04:24 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Unhappy
just to add to the list of Jackd:
*shot temp-sensors, or broken wires of those
*defective backflow valve of the fuel pump
If you are a DIY than start with the simple things like new plugs, check the plug wires, the distributor cap and the rotor, new airfilter, check temperature sensors and their wiring, vacuum leaks in the intake system, function of the cold start valve. Anything beyond that requires more diagnosis tools, such as fuel pressure measurements or checking and replacing the fuel pump and fuel filter (big mess!!!).
If your are no DIY at all than go for Jackd advise and see a mechanic who knows MB well.
Good luck.
Old Oct 14, 2002 | 06:08 AM
spinnell71's Avatar
300 CE
Thenks for the suggestions.
Old Oct 16, 2002 | 10:18 AM
Tazo's Avatar
300CE24
I bet on the cold start valve.
Old Oct 16, 2002 | 11:31 AM
spinnell71's Avatar
300 CE
How do I check the cold start valve??
