Transmission Overload Protection Switch
The switch S65 is fitted to the side of the transmission and is a hydraulic pressure switch in the hydraulic working circuit of brake band B1.
If pressure gets too high, the switch is tripped and the appropriate signal is fed to the ECU which then puts engine into limp home-mode to reduce power and preserve gearbox.
