Draining torque converter
92 500e, 95 E34 525I Touring
just need osme quick directions. I drained the fluid last week but could not figure out how to drain the torque converter and now the problems is back.
Directions and possibly pictures would be much appreciated.
95 E320 Cabriolet, 108K
It's a matter of rotating the torque converter until the drain plug is visible at the bottom window. There are two ways of rotating the torque converter. One is to use a socket on the crank dampner mounting bolt and rotating the engine clockwise. The other is to walk it around using a screwdriver on the flywheel teeth. The drain bolt is a 5mm allen head.
