ABS and ASR light
Old Aug 3, 2007 | 02:53 PM
STLe320's Avatar
95 e320...sold the rest
ABS and ASR light
I was just driving around yesterday, taking my buddy home...and i got back in my car and noticed they were on...what could cause this?
Old Aug 3, 2007 | 09:31 PM
carlson03's Avatar
03 ML500
not sure if its similar to what could be wrong with yours, but a few different things could be wrong...on my brothers 92 300SE, he had to get the wiring harness replaced...just one possiblity, hopefully others can add to it
Old Aug 4, 2007 | 01:39 AM
STLe320's Avatar
it has been running hot lately....from the stereo...that wiring harness?
for some reason the fan is not working how it should...it comes on and off sparatically...and i'm running above the line between 80 and 120
Old Aug 4, 2007 | 06:39 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
No, the engine wiring harness. That is a common cause of this problem. The part is about $850 DIY. I hope this is not your problem.
Old Aug 4, 2007 | 06:42 PM
Eliot's Avatar
Range Rover Classic
The ASR light is bad news. If the wiring harness has never been replaced then I would look at that first. The insulation is biodegradable and will crack with age exposing the wires. The part is exceptionally expensive however you can do the install on your own quite easily. It would take about an hour.
Old Aug 5, 2007 | 06:06 PM
STLe320's Avatar
the asr light only came on once...and it hasnt happened since then, so i guess i'll just let it go until the problem occurs again
Old Aug 8, 2007 | 12:21 PM
White_Knuckles's Avatar
1994 E320 Dragon Wagon
Before fear factor sets in, a little investigation will tell you if the harness has been replaced. First check all exposed connectors that go to temp sensors and other devices like solenoids etc. The harness tape wrapping will not go all the way to the connector ends. The colored wire will be exposed about 1/2 inch. Look for wire insulation cracking. Roll the wire gently with your fingers, it should not split or flake away. There should be no exposed copper wire strands or dread green corrosion evidence.
Mine clearly has basic black zip-ties all over securing the cable tie points. The factory harness was installed with ties but not shiny black zip-ties cut with diagonal cutters leaving sharp points. The best indicator is where the two large harness connectors enter the main modules behind the battery. The thin, black plastic connector covers are cut back a few inches where factory covers would not. It seems the replacement harness may not have included the connectors so they laid the cable down on the original multi-pin connectors and stuffed the ends with grey sealing putty.
This is what my replacement E320 harness looks like. Other installations may vary and include the large factory connectors.
