Electrical problem?
Old Aug 6, 2007 | 04:10 PM
Ernst's Avatar
'91 300D 2.5Turbo
Unhappy Electrical problem?
Dear friends:
Yesterday i was replacing the bulb of the driver door of my 300D 2.5 Turbo when suddenly one wire touched the other one and i saw a small spark, nothing bad. The light doesnt work now, when i turn on the radio on the display says "E 2" and the seat belt sign on the roof starts blinking.
Does someone know whats going on?
Thank you very much.
Old Aug 6, 2007 | 05:03 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
Originally Posted by Ernst
Dear friends:
I assume you checked all the fuses in the main box?
Old Aug 6, 2007 | 05:11 PM
Ernst's Avatar
'91 300D 2.5Turbo
Yes i open the box and all fuses look fine, i havent check them with a tester though, i think i have to do that
Old Aug 8, 2007 | 12:14 AM
carlson03's Avatar
03 ML500
Maybe you can check out Becker's website about the E2 code:
http://www.beckerautosound.com/1432-...ting_tips.html
Hope that helps a little
Old Aug 8, 2007 | 08:19 AM
shdoug's Avatar
^ Be careful- My computer picked up a virus twice on that site...
Old Aug 8, 2007 | 10:17 PM
carlson03's Avatar
03 ML500
Thats interesting...I will keep it in mind...still a helpful site, just use a virus scanner before going to it
Old Aug 8, 2007 | 10:34 PM
shdoug's Avatar
I did, and it caught it and cured it both times. It was in the pop-up.
Old Aug 16, 2007 | 11:38 AM
Ernst's Avatar
'91 300D 2.5Turbo
Thanks for the site ill check it when im at home because i dont wanna get a virus at work i checked the fuses and one of them was broken! good, the radio works now but when i open the driver door the light on the roof doesnt turn on... but when i open the passenger door it does, is there any other box or relay i have to check?
Thanks a lot
Old Mar 25, 2012 | 06:22 PM
William Bradley's Avatar
1993 300D
1993 300D Rear Tail Lamp Issue
Question to all who may be able to help. On my 1993 300D my right rear taillamp bulb lights intermittantly and the "Sensor" on the dash lights orange. All other bulbs in the right rear taillight housing function properly. The bulb is good and I checked ohms between the 6 prong male housing wiring harness and the lamp and I am getting proper juice, so I assume the wire is good. Since all the other bulbs are functional, I assume that the wiring harness is good. Maybe moisture is getting into the taillamp housing and shorting that bulb out? Could there be an issue the the female side of the wiring harness? As, I said sometimes it lights, other times it will not...Any help would be appreciated. Thank you.
billbradley85@yahoo.com
1993 Mercedes Benz 300D
230K
