Shocks or Bushings?
Old Aug 14, 2007 | 02:43 AM
NorCal124's Avatar
W124
Shocks or Bushings?
On the front driver side suspension I'm experiencing constant squeaking. I initially thought it was a lower control arm bushing but when the car is still and I steer the wheel left or right it still squeaks which now points to the shocks. I squeaks regardless when traveling down the road. This has been bugging me for a while. What do you guys think?
Old Aug 14, 2007 | 06:30 AM
cap'n jasper's Avatar
W124
Swaybar bushings are a common cause.
Old Aug 14, 2007 | 11:20 AM
NorCal124's Avatar
W124
Its definitely not the sway bar bushing. You can tell the sound comes directly from behind the wheel and not in front of it where the sway bar is located.
Old Aug 14, 2007 | 12:19 PM
Chappy's Avatar
AMG
Wheel bearings?
Old Aug 14, 2007 | 12:34 PM
NorCal124's Avatar
W124
I believe wheel bearings make a warping sound and only when you're at speed.
Old Aug 14, 2007 | 12:36 PM
Chappy's Avatar
AMG
Mine squealed on the CE....are you getting any front end vibration, as I had that too.
Old Aug 14, 2007 | 01:31 PM
NorCal124's Avatar
W124
No vibration. Just squeaking. It occurs when traveling at speed and it also happens when I'm stationary and turning the wheels which is why I'm looking at the shocks and not the bushings because the bushing barely move when turning but the shock travels significantly. I just want a second opinion or hopefully someone has had this problem before and knows what action to take.
Old Aug 15, 2007 | 09:17 AM
shadowgriffen's Avatar
is a German Tank
My car has started suffering from the same symptoms, what was the cause of yours?
Old Aug 15, 2007 | 01:12 PM
kth286's Avatar
E320 Coupe
Likely to be the steering knuckle swivel joint dried up. See if the rubber seal has split which will confirm.
It is the joint at the end of the front suspension wishbone.
It is a critical item, for the whole of the front suspension depends on it keeping intact.
On early cars you can change the joint, BUT on later 124 ie 320 you have to change the whole wishbone.
At least with a new wishbone you will also have new 2 new bushes which also wear and can cause sloppy steering, knocking, and front tyre wear.
Old Aug 15, 2007 | 03:22 PM
mgw_300e's Avatar
Dora the Explorer
It's probably your control arm bushings - cheap fix.
While you're at it, you might as well change the sway bar bushings, they're cheap, too.
Old Aug 15, 2007 | 03:26 PM
124-Fan's Avatar
Mercedes Benz
From what you describe, I´m pretty sure it´s the ball joint. It dries up, like kth286 said. This is the typical sound when they dry up.
Not much problem replacing it and it´s not expensive.
Cheers,
Old Aug 15, 2007 | 10:39 PM
108.016's Avatar
Does the "squeak" have a hi-pitch sound? I've experienced something of this sort & it turned out to be the shock dampers. Try to oil the shafting & see if it goes away.
Old Aug 16, 2007 | 03:11 AM
NorCal124's Avatar
W124
Yes it is high pitched. Did yours squeak even if you were turning the wheel at a stand still?
Old Aug 18, 2007 | 04:45 AM
108.016's Avatar
Yes, it was more evident on stand-still. Sounded like a "twang" of a spring.
Old Aug 18, 2007 | 12:55 PM
NorCal124's Avatar
W124
Thanks for all the input. I think I have it narrowed down.
