M103 compression specs
Old Aug 16, 2007 | 09:02 AM
Andy_M's Avatar
'90 300E Blk/Tan
Can anyone tell me the compression numbers I should be seeing on the M103 engine in my 90 300E ? 3.0L SOHC
Old Aug 16, 2007 | 02:02 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Not as much the actual number in each cylinder, but the difference between cylinders.
Not sure if MB published a range like they did for the four cylinders ( 147-176PSI ), but they indicate a minimum of 8.5 bar / 125PSI with a max variance between cylinders of 1.5 bar / 22.0PSI.
Prior to my turbo install we had 12.9 bar / 190 PSI with less then a 5 PSI variance betwen cylinders.
This was on a well maintained 1988 M103-12V with 63K miles.
Old Aug 16, 2007 | 02:30 PM
Andy_M's Avatar
'90 300E Blk/Tan
Good. I'm getting 190psi +/- 5 psi. on all but the cylinder that I believe has a burnt valve. Not to shabby for 125k miles......
Old Aug 16, 2007 | 02:33 PM
RBYCC's Avatar
Excellent !!!
