Tranny Issue
Old Aug 16, 2007 | 12:33 PM
Ernst's Avatar
'91 300D 2.5Turbo
Tranny Issue
Hi guys! i drive a 91' 300D 2.5Turbo and lately i've notice that my tranny is not working very good like before, from first gear to second is perfect but sometimes it "stays" longer in second gear until it moves to third, sometimes it goes to 3500 rpm with a normal acceleration, then from third to fourth is perfect again...
I never changed my tranny fluid (i own the car for six months) i checked the trans oil and it has got more than it needs, like 2 centimeters above the highest level.
Should i be concern about the trans oil level?
Could the tranny problem be a vacuum issue or it has to with the oil level?
Thanks!!
Old Aug 16, 2007 | 01:09 PM
RogerJones's Avatar
1996 W124 E320 Coupé, 1990 W124 300E twin turbo, 1991 W126 300 SE, 1984 Ford Capri 2.8i
I'm no expert, but I'd change the automatic-transmission fluid and get the level right. There is a specific procedure for doing this properly, which I expect is somewhere on this site (or elsewhere on the Web). Use the right stuff as per MB spec. And, above all, the approach to the job should be one of surgical cleanliness -- the autobox is a sensitive device.
I had a problem caused by a main dealer failing to refill the box with the correct quantity of ATF; a shortfall in that case, it produced alarming symptoms, and I can imagine that an overfill might do the same. That's when I quit main-dealer servicing, having paid them well over USD1000 for the 36k service.
Old Aug 16, 2007 | 03:59 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
Not to be insulting, but I'd like to check the obvious. Are you checking the fluid level with the car warm, idling, and on a level surface?
What color is the fluid?... pink, red?, or a dark brown or black?
Old Aug 16, 2007 | 04:06 PM
Ernst's Avatar
'91 300D 2.5Turbo
yes, idling, car warm, etc...
the fuid is dark red, normal color i guess and it doesnt smell burnt
Old Aug 16, 2007 | 04:15 PM
Ernst's Avatar
'91 300D 2.5Turbo
The funny thing is that it works almost perfectly when the weather is warm (above 78 Fahrenheit)...
Old Aug 16, 2007 | 04:42 PM
Kestas's Avatar
Sometimes the fluid can look good on a dipstick, yet look black in bulk after it's drained. It may pay to replace the transmission fluid - especially since the car is relatively new to you, and you don't know the maintenance history. It's a cheap and easy thing to do that may solve your problem.
Old Aug 16, 2007 | 04:54 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
Turn the Bowden cable adjustment 1 turn clockwise (inward) to decrease the throttle pressure. If that doesn't make a difference then put it back where it was and check the cold shift delay valve.
Old Aug 16, 2007 | 05:47 PM
Ernst's Avatar
'91 300D 2.5Turbo
Thanks shdoug, ill do that tomorrow!
Old Aug 17, 2007 | 02:30 AM
Rio Z Lander's Avatar
i now drive a ford p71 i also own a 1988 ford f150 lariat
i got some thing like that but i over filed my trany just a tad bit and for some reson it dose not leak fluid any more is this a odd thing or shold i not worry about it my car runs like a dream now and the only problems i need to fix is the heater that runs all the time and the dam bolts that will not come off so i can change out my air filter
Old Aug 17, 2007 | 12:53 PM
shdoug's Avatar
Originally Posted by Rio Z Lander
I've got something like that, but I overfilled my tranny just a tad bit and for some reason it does not leak fluid any more . Is this an odd thing or should I not worry about it? My car runs like a dream now and the only problems I need to fix are the heater that runs all the time and the damn bolts that will not come off, so I can change out my air filter.
Sorry! Just wanted to see what it would look like in English.
Old Aug 17, 2007 | 02:54 PM
shadowgriffen's Avatar
is a German Tank
