Can anyone help me with some torque specs?
Old Aug 20, 2007 | 09:02 AM
Andy_M's Avatar
'90 300E Blk/Tan
Doing a valve job on my '90 300E M103 engine (unexpectedly.) Can someone give me the torque specs for the following:
Head Bolts
Intake manifold bolts
Exhaust manifold bolts
Cam gear bolts
Thanks ahead of time for the help.
Old Aug 20, 2007 | 10:50 AM
RogerJones's Avatar
1996 W124 E320 Coupé, 1990 W124 300E twin turbo, 1991 W126 300 SE, 1984 Ford Capri 2.8i
Head bolts 70Nm stage 1, then angle tighten 90° stage 2 and 90° stage 3. N.B. Follow strict sequence of loosening and tightening the bolts (as you may well know already).
Camshaft-cover bolts 15Nm.
Can't find the others in either the Haynes manual or the MB tech data handbook.
Old Aug 20, 2007 | 08:52 PM
ptoro01's Avatar
86 W124
intake, exhaust and cam are just to a tight point, there is no specific torque. The head is the one that is precise. Make sure you use the right bolts for it and make sure you the proper washers if need be. Most bolts do not need the washer, the ones that have that are fat at the bottom, the ones that are not tappered out need washers. Very important to get it right.
Old Aug 21, 2007 | 08:20 AM
Andy_M's Avatar
'90 300E Blk/Tan
All of the head bolts I removed from the head had washers.
