Is de-chroming really neccesary?
I want my de-chrome the grill suround and have the holes filled. Is de-chroming really neccesary?
I have read a few threads that suggest yes. But so many people have painted grills that I am confused.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Dechroming is not necessary, but proper prep is critical.
You need to rough up the surface of the chrome to begin the process.
Steel wool or a 400 grit wet/dry paper usually will suffice.
Clean the roughed up surface thoroughly, especially if you use steel wool.
Use a quality acid etching primer.
Finish coat as normal.
Should hold up like any other body panel if prepped correctly !!!
i now drive a ford p71 i also own a 1988 ford f150 lariat
Should hold up like any other body panel if prepped correctly !!!![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
here is some of the work i have doon if you would like to see.
along with this stuff i have made metal sculptures around 60 to 70 pounds and armor.
http://i7.photobucket.com/albums/y27...Picture028.jpg
http://i7.photobucket.com/albums/y27...Picture029.jpg
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Thanks yall. I appreaciate the input. I have contacted a local chrome shop here in Honolulu. I need to find a paint shop. I dont want to pay a lot for the paint. I have a good (not great but GOOD) paint shop in San Antonio. But the army has said I will live here in Hi. Oh well I will find a paint shop. Hey do any of yall know any members on Oahu.
Rio Nice work. Ok 2phast I agree I will be "doing it right" when I go back to texas. I am going to try it the wrong way for now. I am calling a body shop supplier in the Am to try and get the paint. I hope it will all work out.
