Need some speed
Old Sep 11, 2007 | 10:57 PM
spmbass's Avatar
1987 300E
Need some speed
hey i was wondering if there is any way to upgrade my 87 300e without spending a billon dollars or a lotta work just wanna make it alittle quicker
Old Sep 12, 2007 | 02:56 AM
Rio Z Lander's Avatar
i now drive a ford p71 i also own a 1988 ford f150 lariat
well thats hard one to tell you ive been looking my self for a long time. plane to throw a V8 in my 260e. the 500e motor. umm i know there are places that sell stuff but i cant find them.same thing with body kits to. cant find any good looking ones. one of the cheapest thing i know is to weld up your own pips and get a bad *** sound to your car that can add 5 to 20hp. just by helping it breath better. i saw a few mods for air filters on ebay.
but not much. it seems people don't really like to mod this car to much other that making it look cool or pimp.
Old Sep 12, 2007 | 12:33 PM
braknstuf's Avatar
E320
The car is moddable but its $$$ and the question is why? if you wanted more HP you should have started with a 500. Thier are a few things though that you can do that may or may not result in neglagable HP increase.
1. Run PREMIUM gas (93+ octante) and fix the ignition retard so you can utilize the extra power - search for the web for the info on this - thier is a resistor that calibrates the retard replace it with a diffrent one to dial in the setting - bonus points for using a rheostat and making it adjustable ( Do a write up for the rest of us ) Also search th web for Taurine - this will go well with the retard mod.
2. For minor money you can polish your intake and mabey add a cold intake pipe to the airbox - anything that helps the car breath better will net you HP - at least in theory. Your intake should match the ports on the head EXACTLY and make sure your gasket doesnt block any portion of the holes - real basic stuff here but thier is HP to be had - cheap if you can do it yourself - expensive if you screw up and have to get new parts.
3. Depending on your emission laws you may be able to get a more free flowing exaust - possibly removing the Cats and mabey a better flowing muffler - Do remember that a 3" exaust will probably do you no good as the engine will need some backpreasure. Big exausts on cars with Turbo's are a bennefit but too large on your car will just be silly - what ever you do dont put one of those coffee cans on it.
I would say that everything else i can think of involves seriously more money (500$) but should you want to do it, start with ECU (renntech), Turbo kit, forged internals, cams, dont forget about Brakes, suspension, swaybars. Just keep in mind this isnt a honda and you wont find parts on every tuner website and auto store, do your reasearch, take your time, and spend the money to do it right.
Old Sep 12, 2007 | 12:49 PM
Eliot's Avatar
Range Rover Classic
You could turbo charge it on the cheep but it would require buying the parts on your own and fabricating the bits and pieces. Otherwise your next least expensive option would be a new car. The 500s and the 400s are fairly cheap at this point.
Old Sep 12, 2007 | 12:58 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
You should be able to get more power with only spending a half a bil !!!!
Seriously....you have a very basic engine.
Doesn't have a ECU that can be programmed.
Has Semi-electronic / mechanical fuel injection.
Has Distributor ignition.
Stock car as it stands was actually fairly quick in it's day.
You could probably purchase a 500E for the cost of installing twin turbos and a suspension that handles the increased power
Old Sep 12, 2007 | 01:47 PM
rooney2006's Avatar
1991 300E
just curious but does the non-amg sprint booster work for the w124? anybody know?
Old Sep 12, 2007 | 02:20 PM
RBYCC's Avatar
Do you mean a device that modifies the ATC ( automatic throttle control) function ?
They apply to electronic throttle control.
W124's are far from drive by wire with a mechanically operated throttle
Old Sep 12, 2007 | 03:59 PM
well a 500e is out of my buget for the time being but yes those things you have put down are good ways of makeing some good hp. also if you go to a good muchine shop for motors and ask them about some specalty shops you could costom ourder soom good parts that will fit your motor and ad alot of bang for the buck. but i warn you prepare to brake out the money gun and start shooting money out like crazy to pay for that stuff. i plane to drop every thing in to my car that the 500e had motor and all and make it a 560e
i have a 260e and doing this should make a 560e R.Z.L costom dont ask how i came up with the number i dont know my self it was a odd night of drunk slander and passing out in my car tell morning over by my house.
Old Sep 12, 2007 | 09:59 PM
carlson03's Avatar
03 ML500
if you want to think that your mercedes is fast, go drive a 2nd generation 4runner, then hop into the mercedes....
Toyota 4runner = slow
mercedes = faster
well, thats just how I do it, plus its cheap
Old Sep 13, 2007 | 01:05 AM
Eliot's Avatar
Range Rover Classic
Suppose thats a cheep solution. Better yet make it a diesel with a malfunctioning turbo.
Old Sep 13, 2007 | 05:04 AM
PaulX608's Avatar
2011 VW cc, 2004 ML350
Mine has an electronic throttle!
Old Sep 13, 2007 | 08:25 AM
RBYCC's Avatar
The OP and questioner of the sprint booster had a 86 and a 91 which are KE-Jetronic III and mechanical throttle.
V8's and 93 and later M104's with LH and HFM had an electronic throttle.
Should have made myself a bit clearer and not generalize, but was addressing the thread subject matter !
Thanks your input !
Ed A.
