car wont start
Old Sep 23, 2007 | 08:31 PM
spmbass's Avatar
1987 300E
car wont start
i got a 300e 87 and it wont start. I have full battery im almost postive it my neutral saftey switch anyone know how to replace or fix it so i can start the car.
Old Sep 23, 2007 | 08:37 PM
jlink38's Avatar
E320
Be more specific... does it crank? Or is it just dead? Do the dash lights go on? Check your relays also.
Old Sep 23, 2007 | 09:27 PM
spmbass's Avatar
1987 300E
No it dont crank no nothing i do have lights n i know the batterys good, i tested it, like said im 99.9% its the neutral saftey switch beacuse its done it before and i would have to play would the shifter to get it to start like put it in neutral or shift it from reverse to park a couple times till it would crank over but this time no matter what i did it wouldnt start. the only other thing i would think is if their is a some sort of inline fuse for the starter or somthing like that cause i was doing electrical work, just hooked up my system so atleast if i want drive my car i have a bad *** system to listen to in my driveway lol.
p.s all my fuses are good in the black fuse box.
Old Sep 24, 2007 | 12:12 AM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
To get it running temporarily, move the shifter around while holding the ignition in the start position.
Old Sep 24, 2007 | 07:40 PM
spmbass's Avatar
1987 300E
ya if that woulda worked i probably woulda done it i figured how to hot wire it my dad looked at it seemed to be fine so im wonderin if maby the key switch is messed up
