meter panel chrome rings
Old Sep 24, 2007 | 01:59 AM
khengwah's Avatar
guys, am stuck here, got some chrome rings for the instrument cluster but cant access it as the instrument cluster is sealed, cant get the plastic panel off due to the glue
need your expert help !
thanks
Old Sep 24, 2007 | 02:54 AM
Eliot's Avatar
Range Rover Classic
What kind of knife did you use to sacrifice the chicken?
Old Sep 24, 2007 | 06:23 AM
khengwah's Avatar
i asked for help, not sarcasm....
Old Sep 24, 2007 | 09:26 AM
Eliot's Avatar
Range Rover Classic
I'm sure someone will be along with your answer soon enough, just hold onto your sense of humour in the mean time.
Old Sep 24, 2007 | 11:49 AM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
thanks
They install from the back.
Very easy to crack the lens if you attempt to take it off !!!
You need to remove the instrument cluster.
Once removed you disassemble the gauges until you have the bare housing.
The rings fit through the gauge holes and secure in place with the tape supplied on the rings.
Old Sep 24, 2007 | 12:01 PM
khengwah's Avatar
thanks!
seems simple enough, just need to be careful i guess.
another thing is the burlwood panel insert on the face plate...wonder how to get it on?
Old Sep 24, 2007 | 12:41 PM
ZedStyle's Avatar
Youngtimer
http://www.mercedesshop.com/Wikka/W124InstCluster
Old Sep 24, 2007 | 11:47 PM
speedracervroom's Avatar
300E
Where do you get the white face plates?
