low shifting point..
Old Sep 26, 2007 | 11:32 PM
s13guy's Avatar
1991 Nissan 240sx, 1986 MB 300e
ok, this is the first problem to address with my 300e..it seems to shift from first to 2nd really early...mabey 3500rpms..not even 20mph..and continues to do it through all the gears...how do i fix/adjust this? the fluids and filter are less than 5000 miles old...and levels are perfect..
i tried searching and didnt find much.
Old Sep 27, 2007 | 02:01 AM
X03's Avatar
X03
MB 1990 300E
keep your foot on the gas
Old Sep 27, 2007 | 09:35 AM
s13guy's Avatar
thats with the pedal all the way down..
Old Sep 27, 2007 | 11:11 AM
crr1612's Avatar
Mercedes benz 1991 300ce(RIP), now an 89 300ce
tighten up your bowden cable, its located under the air filter
Old Sep 27, 2007 | 12:36 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
X2
Old Sep 27, 2007 | 03:52 PM
s13guy's Avatar
the who? dont mean to sound like a dumb-***, but this is my first automatic car..
can anyone post a pic of it for me?
Old Sep 27, 2007 | 07:14 PM
shdoug's Avatar
Sure. Here it is.
File Type: pdf
Old Sep 27, 2007 | 09:45 PM
s13guy's Avatar
ok, i looked at that the other day..just wasnt sure what i was messing with , so i didnt touch it..so which way should this be adjusted?
Old Sep 27, 2007 | 10:55 PM
shdoug's Avatar
Out, which is counter-clockwise to increase the shift RPM. Move it about a half turn at a time until you get it close, then tweak it one flat at a time. Test drive after every adjustment. I had to move mine a good 2 turns before it made any difference, but then it became very sensitive. Be aware that the shift point will be higher until the engine warms up, so do it when it's already hot.
Old Sep 28, 2007 | 12:44 AM
s13guy's Avatar
good deal..will mess with it tomorrow and see how it does..and after a little searching and messing i will have my other question later this weekend.
thanks for the help
Old Sep 28, 2007 | 08:24 AM
spmbass's Avatar
1987 300E
i was having a simliar problem which pissed me off cause i spent 1800 on a new tranny n still wasnt shifting right when my mb mechanic took off the air filter that ***** was completly disconnected. anyway he put it back on n now shifts fine
Old Sep 28, 2007 | 07:36 PM
s13guy's Avatar
wow..what a hell of a difference..now i can really feel the car pull..burns first gear no problem, and barks on the shift to second..
Old Sep 30, 2007 | 10:59 AM
shdoug's Avatar
Also, be aware of the kickdown switch under the accelerator. It took me a couple of months to realize it. If you push the pedal down past the stop, it activates the switch. If you do this at about 25 mph, all hell breaks loose and it's kind of exciting. This switch seems to ignore the bowden cable setting and let the engine shift at redline. You have to step on it pretty hard to activate it. It feels like something might break.
Old Sep 30, 2007 | 12:46 PM
s13guy's Avatar
hmm...i will take a look at that today and try it out...also get some pics up of the car.
