1995 E320 Starts and then dies.
This morning, when I went to start the car I encountered the following:
1. Start the car normally. Car starts and runs for about 6-20 seconds and then dies.
2. While running, car can move forward or reverse in gear until it dies.
3. Engine can be revved during running period, but the car still dies.
4. A "whirring" noise can be heard after the engine cuts out. Noise lasts a few seconds.
5. Car will start again, and then die again. I'm assuming it will do this until the battery is dead.
Any ideas? Anything I should tell the mechanic to look for? Could the mechanic have damaged something while doing the A/C fix and rechage work?
Thanks.
He also recommended replacing the fuel regulator? (not sure if that is correct) for no additional labor cost since it is also original and only costs around $35.
Car has 170,000 miles on it.
I'm having him do the work.
