keyless entry question..
has anyone here install this unit in their w124? i dont understand where to locate the black/white and the black/green wire for the turn signals to connect the diodes.. can anyone help?!...
heres a link to the instructions.. http://fourbyfourclub.com/W124Remote.pdf
Don't bother to hook them up (just remember where you parked your car). Cause it's a pain cause you have to run a wire from under rear right seat to near steering column or emergency flasher switch.
The remote lock also blinks the turn signals to let you know you've locked your car. You can hook a little buzzer to the brown wire (and ground) and leave it under the rear seat for that purpose.
http://cgi.ebay.com/ebaymotors/ws/eB...167709145&rd=1
thanks for the replay! do you think you can go into a little more detailed about where the wires are located and where you connect the diodes?
thanks a bunch for your time!
I am not sure if your car has similar wiring, (I would assume it probably does) but there are a few wires leading to the blinkers. Its a simple test to see which wire is controlled by the blinkers, or by the parking lights. I had thought about hooking them up to my fog lights, but thought that would be too annoying and use too much power....so i just kept what I have gotten
Good luck!
