Funny electrical problems?
Old Nov 15, 2007 | 04:15 PM
carlson03's Avatar
03 ML500
So I have a 260E, when the car is idling, and I have my door open, the dome light dims, this is very noticeable in the dark. If headlights are on, does the same thing. It does this until I rev up the engine. No matter if I have every accessory off or on, it still does this. I just replaced the OVP to fix other problems, but this still persists. I took the car up to Auto Zone to have them test the battery and charging, they said that it was good. I wasn't sure if the voltage regulator would be causing a problem or something else?
Thanks for any help,
Craig
Old Nov 16, 2007 | 08:35 AM
shadowgriffen's Avatar
is a German Tank
Could very well be the voltage regulator.
Old Nov 16, 2007 | 06:20 PM
carlson03's Avatar
03 ML500
I think that I might just order the voltage regulator since its not too expensive from autohausaz.com.
Thanks!
Old Nov 16, 2007 | 06:25 PM
carlson03's Avatar
03 ML500
Also, I went to AutoZone and Advance Auto Parts, both tested that my alternator was kicking out 51amps of power. At AutoZone, they said to replace it, and at Advance Auto Parts, they said it should be fine...so I don't know exactly what to do. Car seems to be running fine, besides the dimming (and cruise)
Old Nov 16, 2007 | 06:56 PM
ZorroAMG's Avatar
Enzo, my Benzo
I believe our altenators are 90 amp...51 is weak!
Old Nov 16, 2007 | 09:59 PM
carlson03's Avatar
03 ML500
so is the only way to fix that to replace the whole thing? or do you think that the voltage regulator could be messed up and not letting it get the full power flow?
Old Nov 16, 2007 | 10:15 PM
ZorroAMG's Avatar
Enzo, my Benzo
If it's the factory unit, REPLACE IT for sure.....otherwise if its a couple years old, it may be other things...
Old Nov 16, 2007 | 10:22 PM
carlson03's Avatar
03 ML500
yeah, its only about 2 years old....I don't know what else could cause this, any ideas?
Old Nov 19, 2007 | 01:20 AM
is a German Tank
Here's what you do
1. Turn the car on
2. discconect battery cables while car is on
3. If it dies, then buy a new alternator, if it doesnt try voltage regulator and go from there.
do you have a "el CHEAPO" battery? Could also play a role.
Old Nov 19, 2007 | 08:11 AM
carlson03's Avatar
03 ML500
its a sears diehard....not sure if its considered "el cheapo", costed a lot haha
I will try what you say by disconnecting the battery cables
Old Nov 19, 2007 | 05:00 PM
carlson03's Avatar
03 ML500
so I had my car running, unplgued the battery cables and it continued to run....does this mean that my problem could still be my voltage regulator?
Old Nov 19, 2007 | 05:09 PM
carlson03's Avatar
03 ML500
also, I just ran a power test across the battery, and at 2000 rpms, the votage was at 14.1 volts....so does this rule out the possibility of the voltage regulator being faulty?
Thanks for you help!
Old Nov 19, 2007 | 07:39 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
Originally Posted by shadowgriffen
Here's what you do
1. Turn the car on
I have heard that a battery is a battery is a battery (different sizes, of course)
and that what you're paying for is the warranty. Most conventional automotive batteries in moderate environments last about 4 years. In tropical climates they last about 1-2 years.
Old Nov 20, 2007 | 09:16 AM
is a German Tank
I thought the same exact thing, till my 130 dollar battery from Autozone died 4 months into purchase, TWICE!
Old Nov 20, 2007 | 12:27 PM
carlson03's Avatar
03 ML500
so do you have any idea what could be causing my problem?
Old Nov 20, 2007 | 12:46 PM
is a German Tank
How does your lower Alternator harness look? Is it in good shape? Mine was crapped out and was causing all sorts of electircal problems (radio staying on all night, conrer lights staying on without me leaving them on ETC ETC...)
Old Nov 20, 2007 | 04:53 PM
carlson03's Avatar
03 ML500
the harness looks pretty good...
Old Dec 2, 2007 | 04:51 PM
carlson03's Avatar
03 ML500
so I wasn't sure if anyone thought of an idea yet....but I did notice today that the lights still dim while I am driving at high RPMS....not sure if that helps
Old Dec 2, 2007 | 05:45 PM
shdoug's Avatar
Did you replace anything yet? If it were me, I'd replace the alternator or just drive it until it goes out completely. Then it will be easier to troubleshoot.
