Removing resistor = Cold Start Problems ??
Old Nov 18, 2007 | 08:50 PM
xudeck's Avatar
1988 300E
Well, over the summer I removed the resistor and it was fine. Lately, the temperature has been dropping and I having really really bad cold start issues. My battery died, so changed that, still the problem persists. About a month ago I changed the spark plugs so now I am at a total loss.
What could it possibly be? Do you guys think, removing the resistor might have something to do with it?
Took me about a good 15 minutes to get the car started.
Any help or tips would be much appreciated as always gentlemen.
Cheers
Old Nov 18, 2007 | 08:59 PM
xudeck's Avatar
1988 300E
Forgot to add, the ABS light is on and initially when it starts, the moment I give it some gas...it sputters and then dies.
Old Nov 18, 2007 | 09:23 PM
jmoney6's Avatar
1993 Mercedes 300e 4-matic (m103 motor)
That happened to me. Under the fuse box and relay box is a mess of wires. I had to get under there to change out a corroded wire, and didn't put the cover back on correctly, moisture got in there and corroded some wires. It was a $500 fix but my car now works.
Old Nov 18, 2007 | 10:07 PM
xudeck's Avatar
1988 300E
So thats what i have to do? Fix those mess of wires...under the fuse box ?
Old Nov 18, 2007 | 10:14 PM
YNVDIZW124's Avatar
lots of cars
I would check this...
1. OVP relay fuse
2. Cold Start Valve
3. Temp Sensor (Not the green one)
4. Idle control valve ( i would just clean it )
Old Nov 18, 2007 | 10:26 PM
floodkid's Avatar
1986 300E
hmm.. never thought that box had to be sealed that tight. ive had to play with those wires too, no problems so far.
Ill have to go and make sure its sealed up correctly.
have you tried putting the resistor back in?
Old Nov 19, 2007 | 10:32 AM
xudeck's Avatar
1988 300E
Havent really tried anything as of yet. I am at work and its below freezing outside. Not exactly fun. Plus cant get away from my desk for too long.
Prolly gonna take half the day off tomorrow and get it checked out. But I am pretty frustrated at this point. One thing is going wrong after the other, as if it was just beautifully planned.
Ughh....
