cold from left and hot from right
Old Nov 28, 2007 | 08:03 AM
vahagn's Avatar
Hello from Armenia! It is getting cold here.
My 90 W124 E300 blower gives cold air on entier left side of the vehicle's saloon and hot on the right side (on all modes). When the blower in on low mode or when I just switch on the blower (after engine is hot enough) it gives hot air at the beginning, but then it gets cooler and cooler. When I turn off the blower at the end it gives a little hot air.
Any idea , what is wrong there?
Thank you.
Old Nov 28, 2007 | 02:47 PM
jmoney6's Avatar
1993 Mercedes 300e 4-matic (m103 motor)
is there coolant leaking? could be a heater core. Or a bad HVAC panel
Old Nov 28, 2007 | 11:26 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
When the blower is off, the hot water valve defaults to the open position under certain conditions. There's quite a complicated sequence of operation for the HVAC system so I don't remember all the "If Thens" but that is normal. As far as the imbalance from side to side, sounds like a damper flap is in need of repair.
