Wheel size question!
Old Dec 17, 2007 | 05:32 PM
dbow2000's Avatar
'94 E320 '99 CLK320
I have a 94 E320, not lowered. Will this scenario work with no rubbing, etc?
18x8.5 fronts, rears are 18x9.5. ET35 on all 4 corners. 255/35/18 tires on the back, 225/40/18 tires on the front. I'm buying them used. I called discounttiredirect and they think it will work, but I would be more comfortable if I saw that someone was running a similar setup.
Old Dec 17, 2007 | 05:48 PM
YNVDIZW124's Avatar
lots of cars
I've had that set up before but can't really recommend it if you don't want to do work to your fenders. If you want to be more comfortable just go with 18x8 all around with a 38-40mm offset. You can also run 18x9 with a 40mm offset on the rear but not 9.5 because that .5 makes a big difference with the 35mm offset.
Old Dec 17, 2007 | 06:58 PM
ZorroAMG's Avatar
Enzo, my Benzo
Go back to myMB and see my post on the subject
Old Dec 17, 2007 | 07:17 PM
ShanMan's Avatar
'95 E420 SE
...or mine on Benzworld.
