de-cat..?
I took the catalytic converter off my car and replaced it with a stainless steel tube. However, there is little, if any at all, change in the sound.
Would Remus sound nice on the 4 cylinder 124s? I am guessing that the stock rear muffler is dampening all the noises. Oh and I'm not looking for some boy-racer-ish noise. I just want some subtle noises like the BMWs and Volvos.
Actually, I thought about putting a Volvo or BMW rear muffler in and have the exhaust guy hook it up for me. Would this make my car sound like either of them, ever so slightly? Just an idea off the top of my head!
Cheers,
Jeff
I thought the environmentalists had a stranglehold on the auto regs there.If you want a good sound, keep the resonator on, and replace the rear muffler with a magnaflow. I always have great experiences with them. Deep sound with no rasp. My bro had one on his 190E and it sounded real nice. I know they sound great on sixers too...
) I don't think it's an issue.The Magnaflow will pass an MOT and if registered before 1993 doesn't need a cat.
Cheers for the response. I'm only de-catting just to try, cux my cat is stuffed and I have a MB one on order. It will go back on in 2wks' time.
How does the E200/200E W124 Remus muffler sound? I really want to get one but I've heard they are not deep and low as I want, but rather more of a "babbing" noise, like a cheap motorcycle
Any ideas regarding Volvo and BMW noises?
All our exhausts are deeper and low, that's the only way to pass TUV and EC tests, we cannot offer louder exhausts, deeper that we can do.
http://youtube.com/watch?v=7QHgEZvbbFk
He doesn't rev it much tho.
The only clips we have on a 4cyl are the following :
http://youtube.com/watch?v=x5oA_m9bvTM
http://youtube.com/watch?v=NkaydmXSXmA
remus sounds great on BMWs as BMWs are already quite throaty already. So adding a smaller backbox will amplify that. Seeing as the remus boxes Ive seen are only a little bit smaller than stock, they complement BMWs perfectly!
The Remus tail does also look a lot classier and oozes quality as compared to a custom stainless steel backbox. That was something I appreciated when I had it on my S. I just worked with the rest of the system to get it right.
We had a SEBRING backbox on a 230E here in london before. Sounded much better and not silly. I think you may find it at ELITE. Theyre based somewhere in essex. I think they are called Elite Wheels or something close.
Good luck in choosing..
I too thought about taking off the resonator but what you did was way better (i.e. reducing it in size). Do you know what makes the BMWs sound so good? What resonator did you get for your S?
Cheers!
Cheers!
Well basically I tried a couple of things until I was satisfied..Everything was with the Remus fitted already. I was basically adapting my system to work best with it, rather than just take it off and start again.
So the first thing was I took off the centre box and just put a straight pipe in its place. Sounded ok when at stand still. BUT OH MY goodness when you accelerated quickly it sounded so Stupid! Like a loud WHAIL sound, it was so ridiculous I just did a U-turn and went back to the exhaust shop.
So took that off and put a long and narrow box (very rectangular shape not square). Sounded better but a little too loud still on acceleration and obviously wrong sound for the car.
So took that off and basically got a SMALLER version of the original centre box I took off initially. So it was more or less a Small SQUARISH shape, where all the sides were almost equal in length. I'd say it was about 30-35 % smaller all-round than the original centre box that was removed.
Off course, I then realised why there was such a loud whailing sound when I put the straight-pipe on there instead of the box. It was because all the pressure coming through two pipes and then the two cats was literally SLAMMED into the single straight-pipe that I put on there and so it produced an extreme sound WAY past the limit that I wanted. So it required a little dampening/muffling and the small squarish (or oblong) box did the trick.
Then I had Sports cats put on and more problems came as it messed up the sound by adding a HISSING sound that sounded more like a leak than a King-Cobra. So after a bit of ignorance by the shop I suggested it was because the Sport cats were smaller than the stock ones so the pressure difference going into the already modified centre box was causing this sound. So I suggested they fit a tiny muffler about 20cm in lenght, just AFTER the cats and just BEFORE the modified centre box/muffler. Problem solved and the car felt like it was peppier upon acceleration and when I revved it it seemed like it was breathing easier.
I think the systems in Mercs is designed to be as dampened as possible. So it makes sense to just go to the centre box and the rear box and just reduce them in size by around 30%. That way you shouldnt have an annoying drone when you are on the freeway/motorway doing 70mph but it sounds like youre in a light aircraft...
Thats the policy that I have adopted with my Mercs. With my STi its a different story for that bad-boy!
Thanks once again mate!
