Tune up...
Old Dec 24, 2007 | 12:34 PM
RhinoLT's Avatar
95 E300D
Tune up...
Ok... I just picked up my 95e300d, its my firs Diesel car,first thing i like to do with my new cars is Oil change and tune up... For gas cars i usually change spark plugs,wires,air filter... What kinda tuneup i should do for diesel engine if there is one? Thank you in advance.
Old Dec 24, 2007 | 12:43 PM
floodkid's Avatar
1986 300E
same... but no sparkplugs.
oil, Airfilter
If you want to go more. You can change out the glow plugs.
umm... see if you can pick up a turbo from a 300TD. not sure how it would work out and fit on. but i driven one with and without a turbo, and the turbo helps.
Good luck and nice find!
Old Dec 24, 2007 | 06:57 PM
RhinoLT's Avatar
95 E300D
Can i install turbo on this model?
Old Dec 24, 2007 | 09:01 PM
myfirstbenz's Avatar
95 E320, 19 Ram 1500 Hemi, 21 GLS 580(wife)
http://www.mercedessource.com/node/324
Check this out...
Old Dec 24, 2007 | 09:04 PM
neanderthal's Avatar
fuel filter, air filter, oil filter, oil change.
you can get you injectors cleaned. pump should be fine.
id leave well enough alone vis a vis turbo.
youve got a hell of a car as it is.
