Fixing speedometer
Old Dec 25, 2007 | 11:01 AM
Yenkee's Avatar
1989 MB W124 250D
Fixing speedometer
I have trouble with my speedometer. It is working but it is showing greater speed than the real is. At low speed <to around 20> it is off by at least 8 mp/h. But when I am doing 80 mp/h the real speed is pretty much same. Do you guys have any clue where to begin with locating the problem? I got 89 W124 250D. Thanks
Old Dec 25, 2007 | 11:11 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
Do you have non-standard rim and tiresize?
Old Dec 25, 2007 | 11:37 AM
Yenkee's Avatar
1989 MB W124 250D
Nope I got all standard tires 195/65 R15 same as wheels. Thanks tho
Old Dec 25, 2007 | 02:57 PM
1990 300ce 24v I6
sorry, thats really all I've got lol
Old Dec 25, 2007 | 04:07 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
If you look, our speedo's start off at 10 MPH.
I say dont worry about it, they probly are all the same...
Old Dec 25, 2007 | 05:13 PM
neanderthal's Avatar
clean your abs rings.
quite a few cars use a non driven wheels abs sensor as the speedo pickup
Old Dec 25, 2007 | 06:30 PM
Normally this could be a problem, but he said the difference between displayed and actual speeds decreases as he gets faster. This is the opposite of what would happen with most usual problems with a speedometer.
Honestly Im pretty sure its just the fact that I stated before. At a stop, our pin rests at 10 MPH on the gauge. The difference is corrected proportionally up to 20 and from there should be accurate.
Old Jan 5, 2008 | 05:16 PM
Yenkee's Avatar
1989 MB W124 250D
thank you guys
first of all, i will definitely check my abs sensors... sometimes ABS light blinks on, so it might be a cause, too. i didn't know that abs sensor are used as the speedo pickup! I thought that speedometer think is build in the right rear wheel. I will spin my rear wheels tomorrow and check for result whether speed will increase. This might be a solution.
As I sad, speed is quite off until 80 MPH when actual = displayed. The trouble is when I see cops measuring speed of 25MPH. Than I am not sure, at what displayed speed I supposed to drive. So I prefer to be even slower than 25 and not to get ticket... That's why I would love to fix it.
