Keyless problem
Old Jan 3, 2008 | 10:04 AM
cml55's Avatar
Keyless problem
I have a 94 E-320 wagon that has a problem with the battery draining if it is not driven every day. The alternator puts out 90 amps and the battery is new so something is drawing the battery down. The car has an aftermarket Clifford keyless entry system. It has bee acting up and locks and unlocks the doors even when you do not activate the switch, so I want to disconnect it to see if that is the problem. Does anyone know where the control unit is usually mounted? I would guess it is near the power door lock actuator but I am not sure where that is. Any suggestions would be appreciated.
Old Jan 3, 2008 | 01:15 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
I had a mysterious battery drain problem not too long ago. It turned out to be a posessed car alarm that went of whenever it wanted to (like 4am). Is the car parked close to your bedroom?
