Another Transmission Thread....
Old Jan 14, 2008 | 04:19 AM
Geh's Avatar
Geh
2007 GL500, 2007 E280
So My Transmission Has been Leaking For Ages Now, and i finally had time to get it fixed, i was told the pan gasket was leaking, so i got a New Gasket and Fitted it...
The Transmission is Still Leaking, But this Time it seems to be only leaking when the car has been used recently. If I Leave the Car off for the night It wont Leak, But as soon as I have taken her somewhere i get home and theres Transmission Fluid All over My Drive Way.
Can Anyone Point Me in the Right Direction as to where else the Transmission Could Be Leaking from?
Old Jan 14, 2008 | 05:10 AM
battlecat714's Avatar
a TVR Cerbera Speed Twelve
How about where it connects to the rest of the engine?
Old Jan 14, 2008 | 01:42 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
It may not be the pan gasket, but the leak may be higher, wetting the pan gasket in the process.
Old Jan 15, 2008 | 02:16 AM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Try the torque converter drain plug. Wish I would have gotten a picture of it one of the 100s of times I was under mine.
Obviously if its spinning itll throw fluid "all over", but when it stops theres a slim chance itll stop pointing down.
Is it really a lot a fluid? Youre keeping her topped off right?
PS: I like your randomly capitolized letters haha
Old Jan 15, 2008 | 02:38 AM
Geh's Avatar
Geh
Its Not alot.....but enough, its dripping a fair bit not just like one or two Spots theres little Patches so its dripping a fair bit, Sorry i cant explain it much better then that
Haha Yeah you Can Tell i failed English xD
Old Jan 15, 2008 | 03:29 AM
Arnie's Avatar
08 Lexus GS350 AWD. 08 Lexus RX350 AWD - wife's. 94 MBZ E320 - still have it.
Could be the front seal. You would have to drop the AT to replace the front seal.
Old Jan 15, 2008 | 03:52 AM
Geh's Avatar
Geh
omg this sucks i just spent $1600 on a New Sound System i cant afford to get that done anytime soon -_-
Im Going To check it out on the weekend when i get new Jack Stands, ill keep all you guys updated
Old Jan 15, 2008 | 04:18 AM
wfsiew's Avatar
According to ur symptoms:
the leaking problem couldn't at drain plug but it's mostly leak on gearbox seals!
Coz rotating shaft will prompt to leaking instead stationary shaft. so, it's necessary to check ur gearbox shaft seals.
