wheel bearing?
Old Jan 23, 2008 | 02:19 PM
crr1612's Avatar
Mercedes benz 1991 300ce(RIP), now an 89 300ce
wheel bearing?
so quick question. i hear a droning sound coming from the back of my car, get louder as the speed increases. doesnt seem to change with gear changes. it makes my car sound kinda like a plane or loud vacuum cleaner so im thinking its either teh differential or the wheel bearings in the back. a friend of mine had a problem with that sound on his crap saturn, turned out to be bearings. what do you guys think? will application of some bearing grease quiet it up?
Old Jan 23, 2008 | 04:07 PM
berti_00's Avatar
2016 Cls63s AMG
yah dude... its front bearings, when that happend to me i thought my tranny was blown hahaha got scared didnt know what it was but yah anyways after changed that its back to its regular smoth quiet ride
Old Jan 23, 2008 | 04:08 PM
berti_00's Avatar
2016 Cls63s AMG
btw i almost bought a differetial too cuz thatss what i thought but no it wasnt...so my dad just took it to the shop and fixed it lol . this was back wen i first got the car
Old Jan 23, 2008 | 05:42 PM
crr1612's Avatar
wait, front bearings? it sounds like its comin from the back tho..
Old Jan 23, 2008 | 08:24 PM
berti_00's Avatar
2016 Cls63s AMG
i know thats how it sounded to me too lol... but it was front, thats why i thought it was my diff or whatnot
Old Jan 24, 2008 | 08:48 PM
danholm's Avatar
95' E320 Wagon (gave to father) 15' VW TDI Wagon, 05' X3, 97' F150, 99' Buell S3
Jack up each wheel and slowly spin it. If the bearing is bad you will feel It. Also listen for what sounds like gravel in the hub. Fronts are easier to replace than rears, FYI.
Old Mar 16, 2008 | 08:07 PM
crr1612's Avatar
has/can anyone do a write-up on greasing/replacing wheel bearings? also, anyone know how to lube up or clean off the steering wheel shaft...mine squeeks like a **** when i turn the wheel. thanks guys
Old Mar 17, 2008 | 01:17 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
Yes, it is possible to be fooled into thinking that you have a bad rear wheel bearing, when the bad bearing is truly in front. Though it's more common to mix left and right noises.
I've written plenty on servicing front wheel bearings. Search at mercedesshop.com using my name and some proper keywords, such as "bearing" and "preload". I may even have something on this site.
Old Mar 17, 2008 | 02:21 PM
GEDaggett's Avatar
1994 E320 (current)
Greasing a bad wheel bearing is like a 70 year old chain smoker eating a salad. It isn't going to do much for you at all. Just locate the bad bearing and have a new one pressed in.
Old Mar 17, 2008 | 02:58 PM
crr1612's Avatar
why is it necessarily a bad bearing? cant it just be in need of greasing?
Old Mar 17, 2008 | 03:05 PM
Kestas's Avatar
If the bearing is making noise - it's too late, it needs to be replaced. GEDagget is correct, grease will not quiet (and is not a solution to) a noisy bearing.
Old Mar 17, 2008 | 03:21 PM
crr1612's Avatar
fair enough. thanks for the help with that and ill check out the write ups...any thoughts on the steering wheel shaft cleaning/lubing tho?
Old Mar 25, 2008 | 03:08 PM
crr1612's Avatar
just had it checked out...right rear wheel bearing needs replacement. i was quoted $200 not including parts..does this sound about right?
Old Mar 25, 2008 | 03:15 PM
YNVDIZW124's Avatar
lots of cars
That sounds like two hours at $100/hr... yes, it's about right...with parts you'll end up at about $300...They have to have a special puller/installer for it so i hope they don't try to remove the wheel carrier and press it out. They gotta remove the axle too so it's not a pretty job and if your not a DIY'er I would just pay and get it over with.
Old Apr 6, 2011 | 07:10 PM
JSe420's Avatar
1994 E420
Does anyone have a write-up on replacing a rear wheel bearing? Im also looking for a part no. for the puller required to do this job.
Old Apr 10, 2011 | 10:31 PM
JSe420's Avatar
1994 E420
