changing waterpump??
Old Feb 24, 2008 | 01:41 AM
docpaul's Avatar
1991 300E 63K miles in Ice Blue
I am fairly certain my waterpump is leaking. We pressurized the system and it is dripping off the oil pan. Took off air cleaner and looked with mirror but could not actually see the leak but it appears to be from behind the pump...
I searched the forum but found not writeup on how to change the waterpump.
Has someone has done this and posted any instructions?
All the best,
DP
Old Feb 24, 2008 | 10:50 AM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
All the best,
DP
This is from the repair manual.
File Type: pdf
Old Feb 24, 2008 | 11:36 AM
docpaul's Avatar
doesnt look too bad...
Thanks for the file, will give it a shot...
Any advice on sealant?
Permatex RTV blue silcone used on my BMW seemed to work...
Old Feb 25, 2008 | 11:00 AM
andi5's Avatar
MB 300E
All the best,
DP
Just did mine, and it's not bad at all.
You will need the right tools, 3 of the 4 bolts that hold the pump are torx.
I had to take the strut out that holds the engine to get to the bolts.
Took about 4.5 hours.
