Deleting Resonator/RE-grounding amps
SO...I have to swerve rather hard to the left into the oncoming lane and as i was doing this, my back and spun out a little, and once I corrected it the sub box had slid all over my trunk, knocking my amps wires out, all the grounds, and whatnot.
And I was thinking, and when I wired this car I did it rather carelessly and quick. The question I'm asking is: Where is a good/safe place to re-ground my amps??
About the resonator now... Is this a possible DIY if you have correct tools? I have a welder..sawzall.. Anything else I might need?
Maybe someone can give me some tips about doing it, I'll do a step by step progress of it. OH yeah...lol...I forgot! All I'm gonna say is Ultrasuede...
okay, the lecture part of the class is over.
I grounded my amp to one of the bolts holding the gas tank on. It attaches to 4 long threaded studs. There was enough thread left on the stud that I was able to get a second nut on it and sandwich the ground cable (using a proper connector on the wire) between the two nuts. Good luck.
Or if you really want to just remove the resonator it should be easy enough. Just cut it out with a sawzall, and assuming you have some of the right tubing, weld the new piece on. I hope you have access to a lift?
And I do have access to a lift at my friend's shop...so how much of a difference in sound would that make?
