bad flex disk or other???
Old Mar 26, 2008 | 05:36 PM
ShanMan's Avatar
'95 E420 SE
When I romp on it, and am shifting from first to second gear under full throttle acceleration, I hear a squeak that sounds an aweful lot like rubber and the shift is a little "soft". Everything else after that is fine.
Is it possible that I am putting too much strain on a semi-worn out flexdisk or could it be something different. bear in mind that in normal driving situations, the car works perfectly normal...no odd noises and no clinks, clunks or vibration.
Thanks in advance for any insights and/or suggestions.
Old Mar 26, 2008 | 07:16 PM
CDP's Avatar
CDP
W124's
How are the gear changes when you switch gears? Its it rough or pretty loose?
Sounds like your Shifter Bushings has gone bad. Mine did the exact same thing but that's just my experience Shannon.
Old Mar 27, 2008 | 11:50 AM
ShanMan's Avatar
'95 E420 SE
Hey Chris....dude, your car looks very, very niiice bro...now then:
No, the car is tight in terms of shifting from first through forth during regular driving, and second through fourth when on the gas hard...no noises, no looseness, no vibration. That one particular shift under full load seems a bit "softer" or with a slight slip more-so than the others, but it's a bit understandable considering it is the most aggressive shift condition.
What it really sounds like is a belt slipping. You know, that quick chirp or squeak as a belt slips on a pully? Maybe I'll swap out or readjust the surpintine belt to see if the noise goes away. I have never had a car that didn't have mechanical U-joints, so I figured there was a possibility that I am stretching a flex disk (with which I am unfamiliar of the failure mode) and that is the cause for the noise and a slightly "soft" shift. Am I way off-base here?
