Headlight leveling system
Old Mar 27, 2008 | 06:02 PM
Rahray's Avatar
93 400E, 91 500sl, 2001 E320
Was gathering the parts to hook up the headlight leveling system on the european headlights. Got everything but the T or Y connectors. Bought the vacuum hose from the dealer but he didn't have the right size connectors. Didn't think much of it figuring I could go to any McParts store and get them. As it turns out they didn't have anything either. Anyone have a source or part# for these connectors. I know the vacuum hose is 4mm od.
Old Mar 27, 2008 | 11:04 PM
ZedStyle's Avatar
Youngtimer
take the hose with you to an aquarium store or garden store, they use those types of connectors in those sizes
Old Mar 28, 2008 | 09:03 AM
Jim's500E's Avatar
Smile
You need 3 of 124-800-44-15 ....were about 16$ each.
Not sure if you can buy in the USA w/o a euro-VIN with a USA reg. though. I can get 4u them if you can't.
Yellow connector goes to the headlamp, black nipple goes to the interior dial/switch. You cut the purple plastic hose in half and put each end on whatever tubing you use in between. You'll need the check valve also...got one?
Old Mar 28, 2008 | 09:32 AM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Also most home centers ( Lowe's, Home Depot ) .
Look where they sell the bulk tubing.
Fittings are nothing special, just a barbed tube fitting.
If you can't find the "y", then just use a "T"
Old Mar 30, 2008 | 07:00 AM
Rahray's Avatar
Just an update. It turns out the connectors are those used on older mercedes. I went to an online parts store and keyed in a 1981 380 SL and used vacuum for the keyword. The connectors were there as well as the check valve I needed. The check valve is the blue and black one by the way. Thanks for everyone's help
